Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > DC Unlocker
Old 04-27-2017, 10:16   #1 (permalink)
Member: 104766
Thanks Meter: 4
Check account status Access denied (for using protocol monitoring software)
User : 00013F0A
The Following User Says Thank You to yohbz For This Useful Post:
Old 04-27-2017, 13:52   #2 (permalink)
Member: 2023196
Thanks Meter: 1,891
Your computer runs usb activity scanning/sharing service, therefore you got blocked. You must remove such service/software from computer before using DC-unlocker otherwise you will get blocked again.
Block now removed. If you do not know what service/software on your machine causes this then can suggest only to use dc-unlocker from another pc. Note: receiving multiple blocks for same reason may end up with a permanent block.
The Following 2 Users Say Thank You to Namelocked For This Useful Post:
Old 04-27-2017, 15:02   #3 (permalink)
Member: 104766
Thanks Meter: 4
i think it flexihub, now its working tnx, can use the latest software of dc?
User : 00013F0A
Credits left : 48
Support till : 9/30/2014
Old 04-27-2017, 15:28   #4 (permalink)
Member: 2023196
Thanks Meter: 1,891
Yes, flexihub can cause this, now can use.
The Following User Says Thank You to Namelocked For This Useful Post:
Old 04-27-2017, 15:42   #5 (permalink)
Member: 104766
Thanks Meter: 4
manufacturer - Huawei phones
model - Auto detect (recommended)
Found Applications port COM37
Found Diagnostics port COM39
Found Phone : HUAWEISCL-L04
Model : Huawei Qualcomm Android phone
IMEI : 867XXXXXXXX8104
Serial NR. : 8ST7N1XXXXXX0928
Firmware : MSM8909C900B140_AMSSSep15201517:24:57
Hardware ver. : HL3SCALEM
Reading unlock codes...
2017.04.27 22:40:20.191 Logging enabled !
Error connecting to server.....
whats is the problem?
Old 04-27-2017, 15:58   #6 (permalink)
Member: 2023196
Thanks Meter: 1,891
No more blocks on dongle, maybe IP has, please provide it and we will check.
Old 04-27-2017, 16:14   #7 (permalink)
Member: 104766
Thanks Meter: 4
49.144.204.133 my public ip
Old 04-27-2017, 16:21   #8 (permalink)
Member: 2023196
Thanks Meter: 1,891
No blocks on you on our side, therefore problem somewhere on yours. Disconnect modem/router if there is any connected for unlock, Try disabling firewall and antivirus software temporary while trying to log in/unlock. Connection won't work if you use proxy or connect from VPN. If none of these things helped then only using different internet connection method may help.
Old 04-27-2017, 17:18   #9 (permalink)
Member: 104766
Thanks Meter: 4
Server message :
Renew dongle support in order to use latest software versions! More information: https://www.dc-unlocker.com/dongle-support
is this the reason why i have an error?
Old 04-28-2017, 08:04   #10 (permalink)
Member: 2023196
Thanks Meter: 1,891
No, but in order to use dongle need to renew it's support first as explained in link that software gives.
Old 03-14-2020, 11:53   #11 (permalink)
Member: 319131
Thanks Meter: 25
2020-03-14 13:52:33.605 Checking account 00031F69...
2020-03-14 13:52:33.618 Connecting to server...
2020-03-14 13:52:39.482 Connect fail!
2020-03-14 13:52:39.487 Connecting to server...
2020-03-14 13:52:45.220 Connect fail!
2020-03-14 13:52:45.222 Connecting to server...
2020-03-14 13:52:50.942 Connect fail!
2020-03-14 13:52:50.948 Testing servers...
2020-03-14 13:53:02.126 Testing servers Done!
2020-03-14 13:53:02.132 Connecting to server...
2020-03-14 13:53:02.405 Connected!
There was a FlexiHUB program, already deleted
Old 03-16-2020, 14:21   #12 (permalink)
Member: 2023196
Thanks Meter: 1,891
Solved on another platform.
Old 05-04-2020, 17:45   #13 (permalink)
Member: 196365
Thanks Meter: 35
Can You help please?
0000B695
How and why is it?
Honestly I have done anything wrong, what software can do it? Kaspersky can block connection? I haven't got any other monitoring. I was reading abut it. Sharing USB? I don't share any USB connections, never, please help.
Old 05-05-2020, 14:46   #14 (permalink)
Member: 2023196
Thanks Meter: 1,891
0000B695
How and why is it?
Block now removed. If you do not know what service/software on your machine causes this then can only suggest to use dc-unlocker from another pc. Note: receiving multiple blocks for same reason may end up with a permanent block.
Old 05-05-2020, 17:04   #15 (permalink)
Member: 196365
Thanks Meter: 35
Thank You,
is it any tool which can scan system and check in log what's affecting it?
Page generated in 0.22601 seconds with 8 queries
