03-26-2019, 12:30 | #1 (permalink) |
Registered User Join Date: Oct 2012
Member: 1822958 Status: Offline Thanks Meter: 45 | WARNING: P20 pro, mate 20 pro etc but when i tested it out the bootloader writes fine then the device reboots to fastboot where it makes a fruitless attempt to flash the oeminfo partition via fastboot (of course this doesnt work as the bootloader is locked) thinking i must be doing something wrong as it clearly states an unlocked bootloader is not needed i went to the live chat where i was told that it is actually a very hit and miss process which doesnt work more often than it does, heres the chat: they have offered a refund but im still stuck with a useless device Last edited by Namelocked; 03-26-2019 at 16:59. |
03-26-2019, 12:49 | #2 (permalink) |
No Life Poster Join Date: Oct 2017 Location: on google.com
Member: 2771307 Status: Offline Thanks Meter: 772 | Just disassembly phone and use HCU with DC Phoenix to covert it no other way. Need use testpoint and Huawei 1.0 state to change from demo to normal phone mode. http://forum.gsmhosting.com/vbb/f100...other-2533473/ |
The Following User Says Thank You to IMEI_info For This Useful Post: |
03-26-2019, 19:40 | #3 (permalink) |
Insane Poster Join Date: Mar 2014 Location: Egypt
Member: 2143962 Status: Offline Sonork: 1669485 Thanks Meter: 9 | i have question if i have board firmware can i use it for remove demo by the first flash motherboard firmware then flash stock is tis way can remove demo ?????? |
