Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > DC Unlocker
Old 01-13-2021, 10:02   #1 (permalink)
Member: 2214018
Sonork: supper
Thanks Meter: 7
p20 lite, mate10 lite, honor 9 lite etc..after imei repair imei 000000
hi team
i tested p20 lite, mate10 lite, honor 9 lite etc..after imei repair imei 000000 pls fix this problem. i used test point method and hig versiyon 9.1.0
Old 01-13-2021, 10:18   #2 (permalink)
Faheem Anjum's Avatar
Member: 399832
Sonork: Faheem Anjum
Thanks Meter: 24,310
Originally Posted by ctsgsm View Post
hi team
just do factory reset once you will see imei
Old 01-13-2021, 10:19   #3 (permalink)
Member: 2023196
Thanks Meter: 1,891
Hello and thank you for report, fix is on the way. Will update here when it's out.
The Following User Says Thank You to Namelocked For This Useful Post:
Old 01-13-2021, 17:41   #4 (permalink)
Member: 462382
Thanks Meter: 9
please sir solved this problem only in kirin 695x
thanks in advance
Old 01-14-2021, 13:45   #5 (permalink)
Member: 2023196
Thanks Meter: 1,891
hi team
Please try on this version: HCU.exe v.370
https://files.dc-unlocker.com/get/6b...6497e726a9e399 let us know if it helps or not.
Old 01-18-2021, 10:13   #6 (permalink)
Member: 87364
Thanks Meter: 64
HCU.exe v3.70 not work.
How repair IMEI P20 lite becouse i Have IMEI: 000000000
Old 01-18-2021, 10:49   #7 (permalink)
Member: 2023196
Thanks Meter: 1,891
Link now updated to working version, thank you for informing/noticing.
Old 01-18-2021, 11:42   #8 (permalink)
Member: 2318616
Thanks Meter: 16
Website is still showing HCU-Client v1.0.0.0369. please update link.
Old 01-18-2021, 12:04   #9 (permalink)
Member: 87364
Thanks Meter: 64
After repair IMEI the same problem IMEI:000000000:
18.01.2021 11:51:40
HCU Client v1.0.0.0370
Account: 013258E7
Before operation turn phone to TestPoint mode:
Turn off phone, then short TestPoint on phone pcb
and plug USB cable
Wait for device "HUAWEI USB COM 1.0" in Ports
Repair
2021-01-18 11:51:40.922 Fixed IMEI1 CRC: 869828030429421
New IMEI 1 : 869828030429421
New downgrade/customization limitations : UNLOCKED
2021-01-18 11:51:40.937 Selected Cpu/Bootloader - Kirin659_Hi6250_T0_A8.0_V2
2021-01-18 11:51:40.942 Connecting to server...
2021-01-18 11:51:41.168 Connected!
2021-01-18 11:51:42.290 HUAWEI device in Test Point mode Not found!
2021-01-18 11:51:42.384 Reading info...
2021-01-18 11:51:46.963 ImeiFile_I0.hash invalid hash!
2021-01-18 11:51:46.968 ImeiFile_I1.hash invalid hash!
2021-01-18 11:51:46.975 Done!
Fastboot provided info:
CPU: hi6250
Model: ANE-LX1
Firmware: ANE-LX1 9.1.0.306(C432E6R1P7)
Vendor: hw
Country: eu
MEID: 00000000000000
SN: 9WVDU18320009323
PCB SN: DU4VYH183T014260
WIFI MAC: F00FEC5A0104
BT MAC: F00FEC5A08E9
Theme color: black
Device color: black
FBLOCK: 1
Bootloader FB lock: unlocked
Bootloader User lock: locked
Found signed IMEI:
SIM NW_LOCK status: UNLOCKED
SIM NS_LOCK status: UNLOCKED
SIM SP_LOCK status: UNLOCKED
Found NV data:
Modems: 2
IMEI1: 869828030429363
IMEI2: 869828030449528
PESN: 00000000
Found OEM data:
IMEI:869828030429363
IMEI1:869828030449528
MEID:00000000000000
Model: ANE-L21
Firmware: ANE-LX1 9.1.0.132(C432E5R1P7)
Rescue: rescue:ANE-LX1 9.1.0.306(C432E6)
Vendor: hw
Country: eu
Version limitation: OFF
SIMCARDMODE: double
Phone ID: 180CDE9C358C113
2021-01-18 11:51:51.047 Repairing...
2021-01-18 11:51:55.738 Write partition modemnvm_factory...
2021-01-18 11:51:55.930 Write partition modemnvm_factory success!
2021-01-18 11:51:55.948 Write partition modemnvm_img...
2021-01-18 11:51:56.286 Write partition modemnvm_img success!
2021-01-18 11:51:56.304 Write partition modemnvm_system...
2021-01-18 11:51:56.503 Write partition modemnvm_system success!
2021-01-18 11:51:56.522 Write partition modem_secure...
2021-01-18 11:51:57.085 Write partition modem_secure success!
2021-01-18 11:51:57.103 Write partition oeminfo...
2021-01-18 11:51:59.599 Write partition oeminfo success!
2021-01-18 11:51:59.627 Unlocking restrictions...
2021-01-18 11:51:59.653 Unlock restrictions success!
2021-01-18 11:51:59.878 Done!
Old 01-18-2021, 12:46   #10 (permalink)
solgeo's Avatar
Member: 2778414
Thanks Meter: 342
18.01.2021 11:51:40
Account: 013258E7
and plug USB cable
Repair
CPU: hi6250
Model: ANE-LX1
Vendor: hw
Country: eu
Theme color: black
Device color: black
FBLOCK: 1
Found signed IMEI:
Found NV data:
Modems: 2
PESN: 00000000
Found OEM data:
MEID:00000000000000
Model: ANE-L21
Vendor: hw
Country: eu
SIMCARDMODE: double
Very easy
flash via testpoint
ANE-Downgrade-Board-A039-8.0.0.dgtks
repair imei via hcu client
flash again service firmware via rescue mode
Old 01-18-2021, 16:40   #11 (permalink)
Member: 2023196
Thanks Meter: 1,891
Website version won't be updated until provided beta version above is approved.
Old 01-18-2021, 17:01   #12 (permalink)
Member: 2023196
Thanks Meter: 1,891
18.01.2021 11:51:40
Is there signal? Does it show all 0 imei in *#06# or About phone info section or both places?
Old 01-18-2021, 17:19   #13 (permalink)
Member: 87364
Thanks Meter: 64
Thank You
1. Downgrade OK
2. Reair IMEI OK
3. I can`t write firmware. Witch firmware, via Testpoint because? What thas it maint via rescue mode?
Old 01-18-2021, 17:49   #14 (permalink)
Member: 2023196
Thanks Meter: 1,891
Thank You
1. Downgrade OK
2. Reair IMEI OK
We have updated problem on server side, now repair should work normally on 370 version and imei should show correctly on mobile.
Old 01-18-2021, 19:43   #15 (permalink)
J3soft's Avatar
Member: 448639
Thanks Meter: 165
hi hcu team t
open ver 3.70 ok
change imei repair ok
but "not service" not signal
how repair?
thanks
Page generated in 0.21257 seconds with 8 queries
