04-30-2020, 09:15 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: GOOD
Member: 388862 Status: Offline Thanks Meter: 107 | Advanced update Not Reboot NOT cheked Update Verlist to server on file load checked Try Rescue Recovery checked Bypass version check checked Old slow algo NOT checked Looking for a device in upgrade mode COM47: DBAdapter Reserved Interface (COM47) COM48: Android Adapter PCUI (COM48) 2020/4/30 16:13:50 Starting to write device in UPGRADE mode... Device found: XPL0219A25005245 Old slow algo NOT selected 2020/4/30 16:13:52 start to write update file File to update: E:\Hisuite\TAS-LGRP3-CHN 10.0.0.205\full\update_full_base_temp\UPDATE.APP File size: 5,180,317,320 bytes Current version(BASE_VER): TAS-LGRP3-CHN 10.0.0.201 Process identifier:24170663 Validating file... Looking for attached port... Preparing to write... Bypass version checked Checking partition ... Writing file 1 of 51: SHA256RSA...OK Writing file 2 of 51: CRC...OK Writing file 3 of 51: BASE_VERLIST... Error downloading file 3 of 51 Build number: :TAS-AN00 10.0.0.205(C00E201R5P3) Model: TAS-AN00 Vendor/Country: all/cn Battery state: 3793mv OEM lock state info: FB LockState: LOCKED USER LockState: LOCKED OEM get bootinfo: locked Getting base version... Base Version: TAS-LGRP3-CHN 10.0.0.205 Getting cust version... Cust Version: TAS-AN00-CUST 10.0.0.201(C00) Getting preload version... Preload Version: TAS-AN00-PRELOAD 10.0.0.3(C00R5) Process identifier:24178093 Erasing ver .. . File size: 5,177,136,092 bytes Current version(BASE_VER): TAS-LGRP3-CHN 10.0.0.170 Writing rescue_recovery partition RESCUE_RECOVERY partition update :FAIL partition length get error Uptade recovery parttion FAIL Cannot enter in Recovey mode DC Phoenix 0.0.0.126 user:013XXXXX Advanced update Not Reboot cheked Update Verlist to server on file load checked Try Rescue Recovery checked Bypass version check checked Old slow algo NOT checked Looking for a device in upgrade mode COM36: Android Adapter PCUI (COM36) COM35: DBAdapter Reserved Interface (COM35) 2020/4/30 21:31:38 Starting to write device in UPGRADE mode... No devices detected in fastboot mode Old slow algo NOT selected 2020/4/30 21:31:39 start to write update file File to update: E:\10.0.0.205\10.0.0.173\update_sd_base\UPDATE.APP File size: 5,177,136,092 bytes Current version(BASE_VER): TAS-LGRP3-CHN 10.0.0.170 Process identifier:24178113 Validating file... Looking for attached port... Preparing to write... Bypass version checked Checking partition ... Writing file 1 of 54: SHA256RSA...OK Writing file 2 of 54: CRC...OK Writing file 3 of 54: BASE_VERLIST... Error downloading file 3 of 54 Last edited by Namelocked; 04-30-2020 at 16:24. |
04-30-2020, 16:27 | #2 (permalink) |
Product Supporter Join Date: Sep 2013 Location: Lithuania, Kaunas
Member: 2023196 Status: Offline Thanks Meter: 1,891 | Means as written in update info, server does not know your phone's version yet, in which case you would need to put check mark on update verlist to server option then select firmware files (same version as one currently running in your mobile), then can select firmware version that you are currently attempting to flash it with and continue. |
The Following User Says Thank You to Namelocked For This Useful Post: |
04-30-2020, 23:35 | #3 (permalink) | |
Member: 388862 Status: Offline Thanks Meter: 107 | Update Verlist to server on file load checked Bypass version check checked 1---my phone's version : (bootloader) :TAS-AN00 10.0.0.205(C00E201R5P3) (bootloader) :TAS-LGRP3-CHN 10.0.0.205 (bootloader) :TAS-AN00-CUST 10.0.0.201(C00) (bootloader) :TAS-AN00-PRELOAD 10.0.0.3(C00R5) 2--- select firmware files : Hisuite\TAS-LGRP3-CHN 10.0.0.205 Build number: :TAS-AN00 10.0.0.205(C00E201R5P3) Model: TAS-AN00 Vendor/Country: all/cn Battery state: 3793mv OEM lock state info: FB LockState: LOCKED USER LockState: LOCKED OEM get bootinfo: locked Getting base version... Base Version: TAS-LGRP3-CHN 10.0.0.205 Getting cust version... Cust Version: TAS-AN00-CUST 10.0.0.201(C00) Getting preload version... Preload Version: TAS-AN00-PRELOAD 10.0.0.3(C00R5) Process identifier:24178093 Quote:
TAS-AN00 10.0.0.205(C00E201R5P3) can downgrade to 10.0.0.173 ?????? Add huawei newer devices downgrade !!!! The market demand is greater !!!!! Last edited by Namelocked; 05-04-2020 at 14:56. | |
