LCD Refurbish All things related to LCD / Screen refurbish and repair |
03-01-2013, 21:52 | #1 (permalink) |
Junior Member Join Date: Mar 2013
Member: 1892481 Status: Offline Thanks Meter: 4 | iphone 5 Glass separation Proof on lcd out of glass the glue is harder to remove than the glass can be seen in picture |
The Following User Says Thank You to iRepairUK For This Useful Post: |
03-02-2013, 23:27 | #3 (permalink) |
Member: 1892481 Status: Offline Thanks Meter: 4 | we are keeping that to ourselfs at the momenet we do use Molybdenum String though http://www.youtube.com/watch?v=EzLXXfPYezU |
03-03-2013, 12:36 | #7 (permalink) |
Registered User Join Date: Jan 2006 Location: Romania Age: 39
Member: 215866 Status: Offline Sonork: 100.1617874 Thanks Meter: 125 | it is not a secret Glass screen only replacement for the galaxy s2, s3, iphone 4, 4s, 5, - YouTube I personally do this on a htc 8x by removing in small pieces , one by one the old digitizer and took me a long time to finish the job Last edited by nae; 03-03-2013 at 12:42. |
The Following User Says Thank You to nae For This Useful Post: |
03-03-2013, 16:40 | #8 (permalink) | |
Member: 1892481 Status: Offline Thanks Meter: 4 | Quote:
takes us about 4 minutes to remove any glass most of that is on our heat pad | |
03-05-2013, 08:56 | #11 (permalink) |
Junior Member Join Date: Jan 2008
Member: 681965 Status: Offline Thanks Meter: 4 | what are those heating pads called? I don't know what to search for... searching heating pads brings up dog beds.. I wanna try this.. How hard is it cleaning the glue off the LCD? And how hard is it when assembling to not get dust and air bubbles in between? Lastly is it as strong as original? i.e; can you separate again easily?? Great solution for iPhone 5 screens!! |
03-05-2013, 09:00 | #12 (permalink) | |
Member: 681965 Status: Offline Thanks Meter: 4 | Quote: Correct me if I'm wrong are you separating the glass lens from the digitiser and LCD? So once separated your LCD has two connectors attached right? | |
03-05-2013, 10:45 | #13 (permalink) | |
03-05-2013, 10:47 | #14 (permalink) | |
