Go Back   GSM-Forum > GSM & CDMA Phones Hardware Repair Area > LCD Refurbish
LCD Refurbish All things related to LCD / Screen refurbish and repair
Old 04-04-2014, 13:29   #46 (permalink)
ebry's Avatar
Member: 127240
Thanks Meter: 82
Yellow marks here as well. Any idea guys?
Old 03-24-2015, 05:24   #47 (permalink)
Member: 1406622
Smile sometime i feel loca glue is not good for repair
loca always turn yellow in a few days . i did try many many screen using loca . i think almost 50% will turn yellow .
finally i guess the problem is my uv light is not power enough . do not use 36W nails uv .. thats nothing to use .. the light bulb so suck . after use a month , u have to replace new bulb /////////////////////whatever the bulb still light on .. thats cannot fully cure the glue .. some of glue didnt dry very well . thats why a few days it will turn yellow and damaged the screen .
i try to cure same screen in different days .Around 5 days later if the lcd didn't turn yellow . then i install to THE phone . that will more safe ..
i m going to purchase the led uv that sell on ebay for $89 that one . it seem super bright . i think that one is good to cure loca glue .
i also purchased oca film let see which one is prefect for repair screen .
sorry for bad engish . hope my experience can help you ..
Old 07-03-2015, 11:39   #48 (permalink)
Member: 2356101
Any need for iPhone 5 glass replacement you can search google with keywords "hcqs iphone lcd replacement".
Old 01-26-2017, 15:17   #49 (permalink)
Member: 2135622
Anyone? I'm having the same problem. The OCA liquid keeps seeping into the backlight
Originally Posted by IphoneRefurb View Post
Anyone? I'm having the same problem. The OCA liquid keeps seeping into the backlight...
hi gently use petrol on the glue if possible put a small piece of cloth on glued lcd and then put petrol on the cloth. after one or two minutes replace the cloth and gently remove glue with finger. if any one have problem then message me
Page generated in 0.12975 seconds with 8 queries
