Old 07-22-2023, 22:43   #1 (permalink)
Thanks Meter: 20,332
EFT PRO Dongle V4.5.0 is Released ( Xiaomi Flash OTA From File MI Assistant Mode )
EFT Pro Dongle Update V4.5.0 Build 001 is released :
What's New :
[ XIAOMI] First In The World
  • Added New Listing ( UPDATE )
MI Assistant Mode (Sideload)
You Need To Login With Xiaomi Account
  • Added Download & Flash OTA MI Assistant Mode (Sideload)
  • Added Flash OTA From File MI Assistant Mode (Sideload)
Xiaomi Redmi Note 10S download file and update done by EFT Pro 4.5.0
Previous Version EFT Pro Dongle Feature
[MTK]
New design and Easy menu
Added Forced BROM (method 1)
Added Forced BROM (method 2)
Added Forced BROM without Test Point
Added Samsung forced BROM (PIT Method)
Added write Huawei (UPDATE APP) firmware
Added write Samsung (TAR) firmware
Added write Oppo/Realme (OFP) firmware
Added write EMMC Dump firmware
Added Vivo MT6765 PreLoader
Added direct unlock network MTK (BROM)
Added (Vivo) Disable MDM lock Supported for (2020 to Up)
Added (Vivo) Disable MDM lock Supported for (2019)
Added (Vivo) Disable MDM lock Supported for (Y15S PD2140EF)
Added (Vivo) Disable demo mode
Added (Vivo) Disable orange msg
Added (Vivo) Restore orange msg
Update Samsung Disable MDM Lock
Update Samsung change KG
Update Oppo disable MDM lock
Added New Security 2022/2023 for MTK
Added New Device Support for MTK devices
Added New Device (MTK) Factory Reset/FRP Reset/Write Firmware
Update Write Samsung (TAR) Firmware
[SPD]
Added new models apove 200+ model
Factory reset and FRP Reset
Added write PAC firmware for All SPD
Enter diag mode 2 methods
Read info and IMEI in diag mode
Factory reset in Diag mode ALL mode
Added RSA AUTH Itel/Tecno/Infinix/Realme and more
Added Spd Fix Wireless Test Assistant
Added New Device (SPD) Factory reset/FRP Reset/Write Firmware PAC
[SAMSUNG]
Fix Exynos Boot (Beta)
Bypass Knox Samsung Adb
Bypass Knox Samsung MTP
[Qualcomm]
Enable Diag Mode Without Root
Added New List (Qualcomm New)
Added list Service For (Factory Reset /FRP )
Added list Service For (Factory Reset Oppo /FRP Oppo )
-Qualcomm device support automatic loader
-Support for Qualcomm devices. Select the model
Added New Device Support for Qualcomm devices
Added New Device (Qualcomm) Factory Reset/FRP
Qualcomm Protocol Update To Support More Devices And Brands
Fixed Read Chip Info Oppo Reno Devices
Added New Unlock ID (Huawei)
Added New Reset FRP/UserData Use Firmware (Vivo/Other)
[ APPLE ]
Added BOOT PASSCODE/HELLO IOS 16.4 IPHONE 8/8+/X
Added BOOT PASSCODE/HELLO IOS 16.4 IPAD
Added Generate Activation files ios 15.x/16.x (IPHONE/IPAD) (Without Change SN)
FIX Boot Passcode/Hello IOS 15.x/16.x (IPAD/IPhone)
FIX Mount Passcode/Hello IOS 11.x Up 16.x
Added NEW BOOT PASSCODE/HELLO FOR (IPAD)
Added New Read Account From Backup Folder
[ Rockchip ]
Update Read/Write Flash
More Come Soon ...
Update online without replace it ...
For New User Download File
Kind Regards, Easy Firmware Team
Get Now EFT Dongle From Nearest Distrubutor/Reseller Here
EFT Tool Pro WithoutDongle
The Following 20 Users Say Thank You to easy-team For This Useful Post:
Old 07-22-2023, 23:01   #2 (permalink)
Member: 3035905
Thanks Meter: 56
Thanks a lot
XIAOMI First In The World
Added New Listing UPDATE
MI Assistant Mode Sideload
Added Download & Flash OTA MI Assistant Mode Sideload
Added Flash OTA From File MI Assistant Mode Sideload
The Following User Says Thank You to Sabadalla For This Useful Post:
Old 07-22-2023, 23:12   #3 (permalink)
Y Michael's Avatar
Member: 2947987
Sonork: Null
Thanks Meter: 56
Nice update
Sent from my M2103K19G using Tapatalk
The Following User Says Thank You to Y Michael For This Useful Post:
Old 07-23-2023, 02:39   #4 (permalink)
Member: 2077231
Thanks Meter: 12
which xiaomi account should be put
Old 07-23-2023, 04:11   #5 (permalink)
pintu_das's Avatar
Member: 2325851
Sonork: 100.1680491
Thanks Meter: 2,332
Auth Xiaomi account or personal Xiaomi account need ?
Old 07-23-2023, 07:15   #6 (permalink)
Member: 1185918
Sonork: 100.1617322
Thanks Meter: 380
Xiaomi Sideload is a Partition Management app running on MIUI 13 & Newer for Xiaomi smartphones. with the help of this tool, you can Read & write any Partition on a locked bootloader.
Great Team Carry on
Old 07-23-2023, 08:41   #7 (permalink)
need account mi sir sign in
The Following User Says Thank You to easy-team For This Useful Post:
Old 07-23-2023, 09:06   #8 (permalink)
Member: 1834175
Thanks Meter: 51
wrong
Great Team Carry on
that officially xiaomi update method , already available in XiaoMiTool V2 and miflash Pro no news in that
The Following 3 Users Say Thank You to sonsonsy For This Useful Post:
Old 07-23-2023, 09:18   #9 (permalink)
Member: 2960206
Thanks Meter: 28
downgrade possible ?
Old 07-23-2023, 09:56   #10 (permalink)
no sir not supported now soon
Old 07-23-2023, 10:36   #11 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,988
Oppo A5 2020 Format Update Need
The Following User Says Thank You to Tanha0321 For This Useful Post:
Old 07-23-2023, 11:34   #12 (permalink)
Member: 1161437
Sonork: nokia
Thanks Meter: 39
Next update mi account last security Mode (Sideload)
The Following User Says Thank You to kheuch For This Useful Post:
Old 07-23-2023, 11:41   #13 (permalink)
not supported now sir soon
Old 07-23-2023, 12:34   #14 (permalink)
cellcarcol's Avatar
Member: 138781
Thanks Meter: 843
add for spreadtrum
- read, restore and reset rpmb
- repair SN
- read, write and format backup partitions
- in flashmode(TP)
software more clean
The Following 2 Users Say Thank You to cellcarcol For This Useful Post:
Old 07-23-2023, 15:50   #15 (permalink)
Member: 1984825
Thanks Meter: 221
Waiting For Device Connection...
USB PORT: MediaTek PreLoader USB VCOM_V1632 (Android) (COM19)
Port: MediaTek PreLoader USB VCOM_V1632 (Android) (COM19)
Manufacturer: MediaTek Inc.
OPEN COM PORT... OK
Handshake... OK
Waiting for server........ OK
Read CHIP ID... OK
HW-CODE: 0X766
CPU: MT6765
Read Chip Version... OK
HW-SUBCODE: 0X8A00
HW-VERSION: 0XCA00
SW-VERSION: 0X0000
Read Phone Configuration... OK
Switch TO BROM PORT... OK
Wait for brom... FAIL
[ARG ERR] CONNECTION TIME OUT
Try method 1... FAIL
[PORT ERR] A DEVICE WHICH DOES NOT EXIST WAS SPECIFIED
whats wrong
Page generated in 0.21252 seconds with 8 queries
