01-12-2021, 04:58 | #1 (permalink) |
Freak Poster Join Date: Jul 2009 Location: viet nam
Member: 1067406 Status: Offline Thanks Meter: 5 | Apple Watch series 5 after restore firmware 7.2 erroc not show charging I had restore everything ok,but have problem ,not show charging when charging,how fix it sir? |
01-12-2021, 08:19 | #4 (permalink) |
Member: 1067406 Status: Offline Thanks Meter: 5 | No sir,100% software,i tested 10 more device series 4,5,and all like 1 pan,i had send messeger your main have video clip,check mail please sir,i think you need fix firmware |
01-12-2021, 11:39 | #6 (permalink) |
Member: 1067406 Status: Offline Thanks Meter: 5 | I restore on series 4,5 40mm and 44mm all not show charging and can not power off,i call Teo Dubai ,reseller your service VietNam,his test and chat with you,im sure firmware error 100% |
01-12-2021, 13:55 | #7 (permalink) |
Product Manager Join Date: Aug 2002 Location: MFC
Member: 79315 Status: Offline Thanks Meter: 6,027 | Seems you tell me here also error but as you see ? https://forum.gsmhosting.com/vbb/f10...-error-2938728 anyway , try to post all your restore logs, let's check |
01-12-2021, 15:48 | #8 (permalink) | |
Member: 1067406 Status: Offline Thanks Meter: 5 | Quote:
this topic diffenret,can not show charging after restore,remove charge still report chảging....do you understand my problem sir? | |
01-13-2021, 04:27 | #9 (permalink) |
Member: 1067406 Status: Offline Thanks Meter: 5 | After removing the charger, it still shows the signal is charging, the% of battery does not decrease, and the% of battery increase will still indicate Last edited by .::Gsmdenis::.; 01-13-2021 at 04:52. Reason: DON"T double post, i will not reply until you post logs |
01-13-2021, 14:07 | #10 (permalink) |
Junior Member Join Date: Dec 2017
Member: 2791147 Status: Offline Thanks Meter: 1 | I can also confirm that this is an issue with the S4 and S5 firmware. Once applied the device will show charging even when disconnected from the charger if booted up from charge and wont allow you to power down the device. I have tried this on 5 different i watches all did not have the issue before the firmware change, also replaced hardware and same issue still. This is 100% down to the firmware please address the issue. S3 watches seem too be working fine after the update. |
The Following User Says Thank You to SithLT For This Useful Post: |
01-14-2021, 03:19 | #11 (permalink) | |
01-14-2021, 07:39 | #14 (permalink) |
Member: 79315 Status: Offline Thanks Meter: 6,027 | After restoring with V7.2, you should start trying to pair, which means starting to set the language, and the location then becomes the pairing screen. When you connect the charger, you will see that the charging is normal. Then press the button and the power will be able turn off ! Otherwise , that's hardware issue ! |
01-14-2021, 07:55 | #15 (permalink) | |
