10-14-2021, 02:33 | #1 (permalink) |
Insane Poster Join Date: Feb 2005
Member: 120173 Status: Offline Thanks Meter: 11 | disconnect during flashing watchOS 8.0 on S3 i've tried 3utools, itunes, two original apple cable same problem. any idea, do i have a defective ibus2? thanks [warn] Another operation already in progress! Please wait... [info] Found device in Recovery mode [info] Gettting dfu mode device ... [info] Identified device as Apple Watch S3, n121bap, Watch3,4 [info] changing mode from Recovery to Normal [info] device serial number is FHLWD0QBJ8MT [warn] operation not defined! [done] Operation finished! [warn] Another operation already in progress! Please wait... [info] Waiting for device arrival (timeout 10.000000 seconds) [info] Found device in Recovery mode [info] Gettting dfu mode device ... [info] Identified device as Apple Watch S3, n121bap, Watch3,4 [info] changing mode from Recovery to Normal [info] device serial number is FHLWD0QBJ8MT [warn] operation not defined! [done] Operation finished! [info] Setting the time on iOS 6 and later is only supported in the setup wizard screens before device activation. [erro] No device found, is it plugged in ? [done] Operation finished! [info] Setting the time on iOS 6 and later is only supported in the setup wizard screens before device activation. [erro] No device found, is it plugged in ? [done] Operation finished! [done] Operation finished! [info] Using LOCAL IPSW E:\Downloads\MFC_Watch3,4_8.0_19R346_n121bAP_GPS_R estore_42mm.ipsw [info] using cached version data [info] Found device in Recovery mode [info] Gettting dfu mode device ... [info] Identified device as Apple Watch S3, n121bap, Watch3,4 [info] Extracting BuildManifest from ipsw [data] Product Version: 8.0 [data] Product Build: 19R346 Major: 19 [info] device serial number is FHLWD0QBJ8MT [data] Device supports Image4: true [info] Variant: Customer Erase Install (IPSW) [info] This restore will erase your device data. [info] Checking IPSW for required components... [info] All required components found in IPSW [info] Found ECID 001a6bc230fb00a6 [info] Getting ApNonce in recovery mode... [data] 7E4C303FE3BC2012D710C0229904131619F2AF9FEC6F721D14 1FC1B87E67D4CE [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in recovery mode... [data] 07E16D09298DF8FEDD4898D391D52CA8F5F91F4C [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [info] Using cached filesystem from 'iDeviceTools/MFC_Watch3,4_8.0_19R346_n121bAP_GPS_Restore_42mm/018-78513-002.dmg' [info] Found ECID 001a6bc230fb00a6 [info] Getting ApNonce in recovery mode... [data] 7E4C303FE3BC2012D710C0229904131619F2AF9FEC6F721D14 1FC1B87E67D4CE [info] tts>Trying to fetch new SHSH blob [info] Getting SepNonce in recovery mode... [data] 07E16D09298DF8FEDD4898D391D52CA8F5F91F4C [note] Unable to find BbChipID node [note] Unable to find BbProvisioningManifestKeyHash node [note] Unable to find BbActivationManifestKeyHash node [note] Unable to find BbCalibrationManifestKeyHash node [note] Unable to find BbFactoryActivationManifestKeyHash node [note] Unable to find BbFDRSecurityKeyHash node [note] Unable to find BbSkeyId node [info] Request URL set to https://gs.apple.com/TSS/controller?action=2 [info] Sending TSS request attempt 1... [info] response successfully received [info] tts>Received SHSH blobs [warn] No path for component iBEC in TSS, will fetch from build_identity [info] Extracting iBEC.n121b.RELEASE.im4p... [info] Personalizing IMG4 component iBEC... [info] Sending iBEC (769064 bytes)... [info] Device ecid 001a6bc230fb00a6 disconnect detected! [info] Recovery Mode Environment: [info] iBoot build-version=iBoot-7429.10.23.0.2 [info] iBoot build-style=RELEASE [info] Sending AppleLogo... [warn] No path for component AppleLogo in TSS, will fetch from build_identity [info] Extracting applelogo@132~watch.im4p... [info] Personalizing IMG4 component AppleLogo... [info] Sending AppleLogo (9311 bytes)... [warn] No path for component RestoreTrustCache in TSS, will fetch from build_identity [info] Extracting 018-78664-002.dmg.trustcache... [info] Personalizing IMG4 component RestoreTrustCache... [info] Sending RestoreTrustCache (15580 bytes)... [warn] No path for component RestoreRamDisk in TSS, will fetch from build_identity [info] Extracting 018-78664-002.dmg... [info] Personalizing IMG4 component RestoreRamDisk... [info] Sending RestoreRamDisk (83344226 bytes)... [warn] No path for component RestoreDeviceTree in TSS, will fetch from build_identity [info] Extracting DeviceTree.n121bap.im4p... [info] Personalizing IMG4 component RestoreDeviceTree... [info] Sending RestoreDeviceTree (32399 bytes)... [warn] No path for component RestoreSEP in TSS, will fetch from build_identity [info] Extracting sep-firmware.n121b.RELEASE.im4p... [info] Personalizing IMG4 component RestoreSEP... [info] Sending RestoreSEP (2476610 bytes)... [warn] No path for component RestoreKernelCache in TSS, will fetch from build_identity [info] Extracting kernelcache.release.watch3... [info] Personalizing IMG4 component RestoreKernelCache... [info] Sending RestoreKernelCache (14323011 bytes)... [info] Device ecid 001a6bc230fb00a6 disconnect detected! [info] About to restore device... [info] Waiting for device... [info] Device is now connected in restore mode... [info] Connecting now... [info] Connected to com.apple.mobile.restored, version 15 [info] Device 65845ebc0498a77a46249b394c1a4c8a3c9f0b4b has successfully entered restore mode [info] Hardware Information: [info] BoardID: 26 [info] ChipID: 32772 [info] UniqueChipID: 7436831184060582 [info] ProductionMode: true [sett] Previous restore exit status: 0x100 [info] Starting FDR listener thread [info] Connecting to FDR client at port 1082 [warn] About to do ctrl handshake [done] Ctrl handshake done (ConnPort = 49158) [warn] Requesting NOT TO Update Baseband [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] About to send RootTicket... [info] Sending RootTicket now... [info] Done sending RootTicket [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Waiting for NAND (28) [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Sending NORData... [info] Found firmware path Firmware/all_flash [erro] zip_name_locate: Firmware/all_flash/manifest [info] Getting firmware manifest from build identity [info] Extracting LLB.n121b.RELEASE.im4p... [info] Personalizing IMG4 component LLB... [info] Extracting applelogo@132~watch.im4p... [info] Personalizing IMG4 component AppleLogo... [info] Extracting dali-ui.n121b.release.im4p... [info] Personalizing IMG4 component Dali... [info] Extracting DeviceTree.n121bap.im4p... [info] Personalizing IMG4 component DeviceTree... [info] Extracting recoverymode@132~watch.im4p... [info] Personalizing IMG4 component RecoveryMode... [info] Extracting iBoot.n121b.RELEASE.im4p... [info] Personalizing IMG4 component iBoot... [info] Extracting sep-firmware.n121b.RELEASE.im4p... [info] Personalizing IMG4 component RestoreSEP... [info] Extracting sep-firmware.n121b.RELEASE.im4p... [info] Personalizing IMG4 component SEP... [info] Sending NORData now... [info] Done sending NORData [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Unmounting filesystems (29) [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] About to send FDR Trust data... [info] Sending FDR Trust data now... [done] sending FDR Trust Data [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Checking for uncollected logs (44) [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Unmounting filesystems (29) [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Creating partition map (11) [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] Creating filesystem (12) [warn] Unknown message type received. Saving to UnknownMessageType.plist [info] About to send filesystem... [info] Connected to ASR [info] Validating the filesystem [info] Filesystem validated [info] Sending filesystem now... [erro] Unable to send data to ASR.Sent 0 of 20 bytes. [erro] Unable to send chunk checksum [erro] Unable to send payload to ASR [erro] Unable to send filesystem [erro] Unable to successfully restore device [info] device disconnect... [erro] Could not read data (-256). Aborting. [erro] Unable to restore device [done] Operation finished! [info] device arrival... new [info] device disconnect... [info] Arrival USB\VID_05AC&PID_12AF\65845EBC0498A77A46249B394C1A 4C8A3C9F0B4B [info] device disconnect... |
