05-02-2021, 04:14 | #1816 (permalink) | |
Product Manager Join Date: Apr 2008 Location: Whitehole throught Blackhole!
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,623 | Xiaomi Redmi 6 (Cereus) Mi Account Removed using Erased Method by Hydra Tool Xiaomi Redmi 6 (Cereus) Mi Account Removed using Erased Method by Hydra Tool 1. Run Hydra MTK Module, Select Brand and Model 2. Go to Service-->Tools-->Xiaoami 3. Choose "Remove Mi Account Erased Method" from Method / Option 4. Execute and connect the device to the computer with data cable 5. wait until the process is completed. Note: Only in MTK devices, Android above 8, need to install VPN software before you connect wify. But, no need VPS software in Qualcomm module even highest miui vesion ie. 12.xx.xx. No need server! No need Credit! No need yearly activation! No need any extra cost . Screen Short: Logs: Quote:
Dipendra Pathak | |
05-02-2021, 04:21 | #1817 (permalink) | |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,623 | Xiaomi Redmi 6A (Cactus) Mi Account Successfully Removed using Erased Method by Hydra Xiaomi Redmi 6A (Cactus) Mi Account Successfully Removed using Erased Method by Hydra 1. Run Hydra MTK Module, Select Brand and Model 2. Go to Service-->Tools-->Xiaoami 3. Choose "Remove Mi Account Erased Method" from Method / Option 4. Execute and connect the device to the computer with data cable 5. wait until the process is completed. Screen Short: Logs: Quote:
Dipendra Pathak | |
05-02-2021, 04:39 | #1818 (permalink) | |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,623 | Xiaomi Redmi Note 4 (Nikel) successfully flashed by Hydra Tool Xiaomi Redmi Note 4 (Nikel) successfully flashed by Hydra Tool 1. Run Hydra MTK Module and Sosc. 2. Choose Brand and Module. 3. Go to "Flash" Tab. 4. Choose Flash file and its location. 5. Click on "Execute" 6. connect device to the computer with USB Data cable 7. Wait until the process is completed. Screen Short: Logs: Quote:
Dipendra Pathak | |
05-02-2021, 04:46 | #1819 (permalink) | |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,623 | oppo f7 (cph1819) erasing user data successfully done by Hydra Too oppo f7 (cph1819) erasing user data successfully done by Hydra Tool 1. Run MTK Tool and choose "Sosc" 2. Choose Brand and Module. 3. Go to "Service"--> "Tool" 4. Choose "Ultra Power Option" 5. Choose "Erese User Data" from "Method / Option" drop down menu. 6. Connect device to computer using USB Data Cable. 7. Wait until the operation is completed. Screen Short: Logs: Quote:
Dipendra Pathak | |
The Following User Says Thank You to Dipendra Pathak For This Useful Post: |
05-02-2021, 04:52 | #1820 (permalink) | |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,623 | Xiaomi Redmi 9 (lancelot) successfully Flashed by Hydra Tool Xiaomi Redmi 9 (lancelot) successfully Flashed by Hydra Tool 1. Run Hydra MTK Module and Sosc. 2. Choose Brand and Module. 3. Go to "Flash" Tab. 4. Choose Flash file and its location. 5. Click on "Execute" 6. connect device to the computer with USB Data cable 7. Wait until the process is completed. Screen Short: Logs: Quote:
Dipendra Pathak | |
05-02-2021, 04:59 | #1821 (permalink) | |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,623 | Huawei DRA-LX9 (Y5P 2020) restoring OEM info successfully done by Hydra Tool Huawei DRA-LX9 (Y5P 2020) restoring OEM info successfully done by Hydra Tool 1. Run MTK Hydra Tool and choose "Sosc". 2. Choose "Brand" and "Module". 3. Go to "Service"--> "Tool" 4. Choose "Huawei" 5. Chose "Restore OEM Info" from "Method/ Option" drop down option. 6. Click "Execute". 7. Connect Device to computer using USB Data Cable. 8. Wait until the operation is completed. Screen Short: Logs: Quote:
Dipendra Pathak | |
05-02-2021, 05:06 | #1822 (permalink) | |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,623 | Xiaomi Redmi 9 (lancelot) Mi Account + FRP successfully removed by Hydra Tool Xiaomi Redmi 9 (lancelot) Mi Account + FRP successfully removed by Hydra Tool 1. Run Hydra MTK Module and choose "Sosc" 2. Select Brand and Model 3. Go to Service-->Tools-->Xiaoami 4. Choose "Remove Mi Account + FRP" from Method / Option 5. Execute and connect the device to the computer with data cable 6. wait until the process is completed. Screen Short: Logs: Quote:
Dipendra Pathak | |
05-03-2021, 02:12 | #1823 (permalink) | |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,623 | Huawei DRA-LX9 (Y5P 2020) NVRAM written successfully done by Hydra Tool Huawei DRA-LX9 (Y5P 2020) NVRAM written successfully done by Hydra Tool 1. Run MTK Tool and choose "Sosc" 2. Choose Brand and Module. 3. Go to "Service"--> "Tool" 4. Choose "NVRAM" 5. Choose "Write NVRAM" from "Method / Option" drop down menu. 6. Connect device to computer using USB Data Cable. 7. Wait until the operation is completed. Screen Short: Logs: Quote:
Dipendra Pathak | |
05-03-2021, 02:16 | #1824 (permalink) | |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,623 | Huawei FRL-L23 (Y9A 2021) restore OEM info successfully done by Hydra Too Huawei FRL-L23 (Y9A 2021) restore OEM info successfully done by Hydra Too 1. Run MTK Tool and choose "Sosc" 2. Choose Brand and Module. 3. Go to "Service"--> "Tool" 4. Choose "NVRAM" 5. Choose "Write NVRAM" from "Method / Option" drop down menu. 6. Connect device to computer using USB Data Cable. 7. Wait until the operation is completed. Screen Short: Logs: Quote:
Dipendra Pathak | |
05-03-2021, 02:26 | #1825 (permalink) | |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,623 | Xiaomi Redmi Note 3 (Kenzo) Universal auto unlock successfully done by Hydra Tool Xiaomi Redmi Note 3 (Kenzo) Universal auto unlock successfully done by Hydra Tool 1. Run Hydra MTK Module and choose "Sosc" Screen Short:2. Select Brand and Model 3. Go to Service-->Xiaoami 4. Choose "Unlock Universal auto" using Flash Mode 5. Execute and connect the device to the computer with data cable 6. wait until the process is completed. Logs: Quote:
Dipendra Pathak | |
05-03-2021, 02:32 | #1826 (permalink) | |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,623 | Xiaomi Redmi 8 (Olive) successfully flashed by Hydra Tool Xiaomi Redmi 8 (Olive) successfully flashed by Hydra Tool 1. Run Hydra Qualcomm Module and Sosc. 2. Choose Brand and Module. 3. Go to "Flash Tool" Tab. 4. Choose Flash file and its location. 5. Click on "Execute" 6. connect device to the computer with USB Data cable 7. Wait until the process is completed. Screen Short: Logs: Quote:
Dipendra Pathak Last edited by Dipendra Pathak; 05-03-2021 at 02:37. | |
05-03-2021, 02:43 | #1827 (permalink) | |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,623 | Xiaomi Redmi Note 7 Lavendra Successfully Flashed by Hydra Tool Xiaomi Redmi Note 7 Lavendra Successfully Flashed by Hydra Tool 1. Run Hydra Qualcomm Module and Sosc. 2. Choose Brand and Module. 3. Go to "Flash Tool" Tab. 4. Choose Flash file and its location. 5. Click on "Flash" 6. connect device to the computer with USB Data cable 7. Wait until the process is completed. Screen Short: Logs: Quote:
Dipendra Pathak | |
05-03-2021, 02:48 | #1828 (permalink) | |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,623 | Xiaomi Redmi 6 Pro (Sa.ku.ra) Sucessfully flashed by Hydra Tool Xiaomi Redmi 6 Pro (Sa.ku.ra) Sucessfully flashed by Hydra Tool 1. Run Hydra Qualcomm Module and Sosc. 2. Choose Brand and Module. 3. Go to "Flash Tool" Tab. 4. Choose Flash file and its location. 5. Click on "Flash" 6. connect device to the computer with USB Data cable 7. Wait until the process is completed. Screen Short: Logs: Quote:
Dipendra Pathak | |
05-03-2021, 02:56 | #1829 (permalink) | |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,623 | Oppo A37F (Neo 9) formatting user data succcessfully done by Hydra Tool Oppo A37F (Neo 9) formatting user data succcessfully done by Hydra Tool 1. Run Qualcomm Tool and choose "Sosc" 2. Choose Brand and Module. 3. Go to "Service"--> "Universal" 4. Choose "Auto" from "Format / Factory Reset" from drop down menu 5. Click on "Execute" 6. Connect device to computer using USB Data Cable. 7. Wait until the operation is completed. Screen Short: Logs: Quote:
Dipendra Pathak | |
05-04-2021, 03:17 | #1830 (permalink) | |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,623 | Xiaomi Redmi 5 Mi Account successfully Removed using Anti Lock Method by Hydra Tool Xiaomi Redmi 5 Mi Account successfully Removed using Anti Lock Method by Hydra Tool 1. Run Hydra MTK Module and choose "Sosc" 2. Select Auto and Auto 3. Go to Service-->Xiaoami 4. Choose "Mi Account" drop down menu 5. Choose "Bypass Anti-relock method 1" using ADB method. 5. Execute and connect the device to the computer with data cable 6. wait until the process is completed. Note: Even you reset your device, Mi Account does not appear again . Screen Short: Logs: Quote:
Dipendra Pathak | |
