10-05-2021, 21:20 | #257 (permalink) | |
No Life Poster Join Date: Apr 2003 Location: Torun, Poland Age: 40
Member: 25996 Status: Offline Thanks Meter: 254 | Quote:
Do you know which app specifically? Just the KnoxGuard from system partition, or something else like the com.sec.enterprise.knox.cloudmdm.smdms? On the other hand, how is the phone recognized on Knox servers? By SN, IMEI, some other unique id? | |
10-07-2021, 04:34 | #258 (permalink) |
Freak Poster Join Date: Jul 2012 Location: Costa Rica
Member: 1790061 Status: Offline Thanks Meter: 63 | Selected model: Nokia TA-1214 (Nokia 2.3) Operation: Repair Software version: 2.6 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0717 Get HW & SW version from device... OK HW VER: CA01, SW VER: 0200, HW SUB CODE: 8A00 Detect chip [MT6761] Get sec config... OK [000000E7] Active sec flags: [SBC SLA DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port_V1632,usb2ser.sys,3.0.1504.0] Device found at COM15 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0717 Get HW & SW version from device... OK HW VER: CA01, SW VER: 0200, HW SUB CODE: 8A00 Detect chip [MT6761] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x557F48FB, 0x284630E8, 0x2EB65C50, 0x3F000E38 Get Chip ID... [MT6761] Get SOC ID... [B16F518B61150D45F9FD1CF5BEB61F9046B0C906386A4B0DBF 1CB3D320A9F6DB] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [24] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x7001005441323833322031FC9659B641 Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x7001005441323833322031FC9659B641 EMMC_BOOT1: 0x0000400000 (4,00Mb) EMMC_BOOT2: 0x0000400000 (4,00Mb) EMMC_RPMB : 0x0000400000 (4,00Mb) EMMC_USER : 0x074A000000 (29,16Gb) RAM INFO: INT_SRAM: 0x0000039000 (228,00Kb) EXT_RAM : 0x0080000000 (2,00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Read product info... OK Product Brand : Nokia Product Manufacturer : HMD Global Product Model : Nokia 2.3 Product Name : Ironman_00WW Product Device : IRM_sprout Board Platform : MT6761 Product Board : MT6761 Build ID : RP1A.200720.011 Build Date : Mon May 10 22:59:46 CST 2021 Display ID : 00WW_3_220_SP02 Security Patch : 2021-05-05 Version SDK : 30 Version Release : 11 Version Codename : REL Read partitions info from phone... OK Read partition "nvdata"... OK Read partition "nvram"... OK Read NVDATA files... OK Read NVRAM files... OK Read IMEI... error(2) Repairing IMEI... IMEI: 354219101313847 Write IMEI [NVDATA]... error(2) Exception: Invalid pointer operation |
10-08-2021, 00:10 | #259 (permalink) |
Insane Poster Join Date: Oct 2011
Member: 1666558 Status: Offline Thanks Meter: 5 | Selected model: Xiaomi M2103K19C (Redmi Note 10T 5G) Operation: Reset Mi Acc Software version: 2.6 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0989 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6833] Get sec config... OK [000000E7] Active sec flags: [SBC SLA DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port,usb2ser.sys,3.0.1504.0] Device found at COM27 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0989 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6833] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x6BB11E0F, 0xAA6F542D, 0x9EBC9446, 0xE562E0F1 Get Chip ID... [MT6833] Get SOC ID... [EDEAC4E3D929A2453F655D514BD5998CF035D81D50646CDE68 835C51D7394E59] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [32] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK UFS CID (FW VER): MT128GASAO4U21 (0605) Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK UFS INFO: UFS_CID : MT128GASAO4U21 UFS_FWVER : 0605 BLOCK_SIZE: 0x0000001000 (4,00Kb) UFS_LU0 : 0x0000400000 (4,00Mb) UFS_LU1 : 0x0000400000 (4,00Mb) UFS_LU2 : 0x1DCB000000 (119,17Gb) RAM INFO: INT_SRAM: 0x0000070000 (448,00Kb) EXT_RAM : 0x0100000000 (4,00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Security partition not found! |
10-09-2021, 19:35 | #260 (permalink) | |
I tinkered with it, and you need to remove the apps responsible for OTA updates. Otherwise, phone also will find, download and update despite root and unlocked bootloader, in my case causing no network issues on A125F with Android 11. I had to redo everything, and go back to Android 10 for basend and IMEI to show up again. | |
10-15-2021, 06:39 | #262 (permalink) |
Insane Poster Join Date: Dec 2016 Location: Uzbekistan Age: 31
Member: 2657592 Status: Offline Thanks Meter: 20 | Selected model: Xiaomi M1908C3JGG (Redmi Note 8 (2021)) Operation: Reset Mi Acc Software version: 2.6 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0707 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6768] Get sec config... OK [000000E7] Active sec flags: [SBC SLA DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek USB Port_V1632,usb2ser.sys,3.0.1504.0] Device found at COM30 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0707 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6768] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0xF5CF2CCB, 0xDD4A2933, 0x00114BBF, 0x424052E7 Get Chip ID... [MT6768] Get SOC ID... [6D4CD27313FAD6890EDABCD4DBCED24DAF8412EC7511368BCC 8A85B89A1FADF5] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [25] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0x90014A68433861503E03102EC04EA727 Load EMI from phone... OK Parse EMI config... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0x90014A68433861503E03102EC04EA727 EMMC_BOOT1: 0x0000400000 (4,00Mb) EMMC_BOOT2: 0x0000400000 (4,00Mb) EMMC_RPMB : 0x0001000000 (16,00Mb) EMMC_USER : 0x0E8F800000 (58,24Gb) RAM INFO: INT_SRAM: 0x0000070000 (448,00Kb) EXT_RAM : 0x0100000000 (4,00Gb) Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Read product info... error(20) Security partition not found! |
10-25-2021, 23:28 | #265 (permalink) |
Crazy Poster Join Date: Feb 2014
Member: 2121390 Status: Offline Thanks Meter: 12 | motorola xt2053-2 Selected model: Mediatek Mediatek Operation: Read Flash Info Software version: 2.6 Parse scatter file... OK Load Rom Images... OK Host Power Off... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Host Power On... OK Wait for device connecting... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek PreLoader USB VCOM (Android),usb2ser.sys,3.0.1504.0] Device found at COM12 [PRELOADER] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Preloader exist. Skip connection verification. Load DownloadAgent... OK Search DA... OK [20] Send bootloader... error(DA_INIT_KEY_FAIL) please add motorola xt2053-2 unlock network frp |
10-26-2021, 10:54 | #266 (permalink) | |
Product Supporter Join Date: Feb 2008 Location: z3x
Member: 706257 Status: Offline Thanks Meter: 5,106 | Quote:
11-04-2021, 04:45 | #267 (permalink) |
Insane Poster Join Date: Feb 2014 Location: Honduras , la ceiba atlantida
Member: 2127804 Status: Offline Thanks Meter: 6 | Please add the repair and patch tab for the samsung a125u, take note as there is a tool that is doing it |
The Following 2 Users Say Thank You to omarnexus For This Useful Post: |
11-08-2021, 21:23 | #268 (permalink) |
Insane Poster Join Date: Aug 2019 Location: Douala Age: 34
Member: 2921175 Status: Offline Sonork: lore Thanks Meter: 8 | Hi team please team fix the redmi mi accounts relock problem after resetting. Tool do the job well but phone relock after some days!!!! |
