04-12-2021, 20:40 | #109 (permalink) |
No Life Poster Join Date: Jul 2011 Location: Nairobi, Kenya
Member: 1610674 Status: Offline Sonork: 210921 Thanks Meter: 217 | thanks for the update please fix network unlock for alcatel v1 5007u Selected model: Alcatel 5007U (1V (2020)) Operation: Unlock network Software version: 1.7 Parse scatter file... OK Load Rom Images... OK Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Get sec config... OK [000000E7] Active sec flags: [SBC SLA DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Device found at COM52 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0xBC52D12E, 0xAE50BC60, 0x090B6E9C, 0xDE45A549 Get Chip ID... [MT6765] Get SOC ID... [8410F2BDA808C6BD1E7ECD11006EFBA312FD730E5976A0D8B9 5463E69B657C7C] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [29] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0xF40122426977696E20100006BAD0B729 Load EMI config from preloader... OK Init EXT RAM... OK Send 2nd DA... OK Get device info... OK EMMC INFO: EMMC_ID : 0xF40122426977696E20100006BAD0B729 EMMC_BOOT1: 0x0000400000 (4.00Mb) EMMC_BOOT2: 0x0000400000 (4.00Mb) EMMC_RPMB : 0x0000400000 (4.00Mb) EMMC_USER : 0x0748000000 (29.13Gb) RAM INFO: INT_SRAM: 0x000003A000 (232.00Kb) EXT_RAM : 0x0080000000 (2.00Gb) Get scatter info... OK Check USB status... USB_HIGH_SPEED Read partitions info from phone... OK Read security partition from phone... OK Read security files... OK Read lock info... error(4) |
04-12-2021, 20:48 | #110 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,558 | Quote:
we will add old security in next update too. | |
04-21-2021, 14:42 | #115 (permalink) | |
Freak Poster Join Date: Aug 2020 Location: Uzbekistan
Member: 2964628 Status: Offline Thanks Meter: 87 | Quote:
I want to buy your product,but i must know.Is pandora box can repair imei of all Mediatek based Huawei smartphones(exactly 2020-year models)? | |
04-22-2021, 16:29 | #116 (permalink) | |
Junior Member Join Date: Mar 2017 Location: Republica Dominicana
Member: 2693343 Status: Offline Thanks Meter: 3 | Alcatel 5007z Failed Unlock Quote:
Operation: Unlock network Software version: 1.7 Host Power Off... OK Switch virtual port to NONE... OK Connect Type-C to HUB... OK Host Power On... OK Wait for device connecting... OK Device found at COM46 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0717 Get HW & SW version from device... OK HW VER: CA01, SW VER: 0200, HW SUB CODE: 8A00 Detect chip [MT6761] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x278C57B2, 0xF429771A, 0x22CC25B3, 0x0BD5BA0F Get Chip ID... [MT6761] Get SOC ID... [C459DCEA8B56E2E21D399426E56D227BC5749FAEBAB74325C8 B4DEA745B7F736] Get sec config... OK [000000E7] AUTH file not found! | |
04-26-2021, 17:34 | #117 (permalink) |
No Life Poster Join Date: Dec 2016 Location: .
Member: 2659717 Status: Offline Thanks Meter: 487 | Add Nokia 2.3 ta-1206 Chipset Mediatek MT6761 Helio A22 (12 nm) OS Android 11 Selected model: Nokia UNKNOWN Operation: Wipe Data Software version: 1.7 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0717 Get HW & SW version from device... OK HW VER: CA01, SW VER: 0200, HW SUB CODE: 8A00 Detect chip [MT6761] Get sec config... OK [000000E7] Active sec flags: [SBC SLA DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Device found at COM33 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0717 Get HW & SW version from device... OK HW VER: CA01, SW VER: 0200, HW SUB CODE: 8A00 Detect chip [MT6761] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0xF56801A5, 0x234AA936, 0x2D47B23B, 0x6A87225D Get Chip ID... [MT6761] Get SOC ID... [284A5E02640BCBDC641B8C5D9E015A7D8C30702CAE4ABCCBC6 A582B03A2706DA] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [30] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0xF40122426977696E20100000039A97C3 Load EMI config from database [DB VER: 56 DB DATE: 04-11-2021] OK [0] Trying EMI [] Init EXT RAM... error(STATUS_EMI_CONTAINER_FILE_NOT_FOUND) |
04-26-2021, 17:35 | #118 (permalink) |
04-29-2021, 21:03 | #120 (permalink) |
Freak Poster Join Date: Sep 2017 Location: china
Member: 2758069 Status: Offline Thanks Meter: 40 | Selected model: Xiaomi M1804C3CT (Redmi 6A) Operation: Read Flash Info Software version: 1.9 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Get sec config... OK [000000E7] Active sec flags: [SBC SLA DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Device found at COM22 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x34CCA6EC, 0x057A9E50, 0x4C48E2B6, 0x2C3BE913 Get Chip ID... [MT6765] Get SOC ID... [82BE26653D2C779EC8179E909F64B58A1D9FD31840ADA85078 DD61A16EBE5F46] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [29] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... No matter how many times I try, it's still here. What's wrong with it |
