04-05-2021, 07:34 | #91 (permalink) | |
No Life Poster Join Date: Feb 2005 Location: MX-KEY is the BEST NOKIA TOOL Age: 50
Member: 116314 Status: Offline Thanks Meter: 147 | Quote:
redmi note 8 pro Begonia , on latest miui V12.0.7.0.QGGMIXM can we repair both imei (tothe origional) without any nv crash or bootloop? or , does this box save important data during flash process? if accidently imei goes corrupted or null, can be solved by rewriting backup. and both imei are alive again without any nv error? | |
04-05-2021, 08:27 | #92 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,558 | Quote:
04-05-2021, 10:05 | #93 (permalink) | |
Junior Member Join Date: Sep 2017 Location: 中国
Member: 2754448 Status: Offline Thanks Meter: 2 | Quote:
I have the same problem Selected model: Mediatek Mediatek Operation: Unlock bootloader Software version: 1.5 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0707 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6768] Get sec config... OK [000000E7] Active sec flags: [SBC SLA DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Device found at COM6 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0707 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6768] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x6EFE8555, 0xDE866100, 0x91878FA5, 0x437CF260 Get Chip ID... [MT6768] Get SOC ID... [028D997D647413AF1A276053C8B02052B3F9FD046D929D4736 CE41CD03F3342A] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [31] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... The model is redmi 9 (m2004j19c) | |
04-07-2021, 13:26 | #95 (permalink) |
No Life Poster Join Date: Jul 2011 Location: Nairobi, Kenya
Member: 1610674 Status: Offline Sonork: 210921 Thanks Meter: 217 | alcatel 5007u already on the supported list but not working Selected model: Alcatel 5007U (1V (2020)) Operation: Read Flash Info Software version: 1.6 Host Power Off... OK Switch virtual port to USB... OK Connect Type-C to BOX... OK Host Power On... OK Wait for device... OK Read usbhost speed... HIGH Read Device Descriptor... Get VID/PID...0E8D/0003 Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Get sec config... OK [000000E7] Active sec flags: [SBC SLA DAA] Advanced Bypass Security... OK Disconnect virtual port... OK Connect Type-C to HUB... OK Wait for device connecting... OK Device found at COM139 [BROM] Open port... OK Send start cmd... OK Get HW code from device... 0766 Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 Detect chip [MT6765] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Get ME ID... OK ME_ID = 0x63336E48, 0x0F1D2BFE, 0x9FE58F8A, 0x2DD7E720 Get Chip ID... [MT6765] Get SOC ID... [3F347E0992B15D1EAC8A4C39CBF2F5C2E7BB768B15F40A2612 BBED3ECE53E50D] Get sec config... OK [000000E0] Load DownloadAgent... OK Search DA... OK [29] Send preloader... OK Start preloader... OK Check preloader answer... OK Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [BROM] Get device info... OK EMMC_ID: 0xF40122426977696E20100006BB66B733 Load EMI config from database [DB VER: 47 DB DATE: 04-02-2021] OK [0] Trying EMI [] Init EXT RAM... error(STATUS_EMI_CONTAINER_FILE_NOT_FOUND) |
04-07-2021, 13:31 | #96 (permalink) |
Member: 1610674 Status: Offline Sonork: 210921 Thanks Meter: 217 | also please addd direct memory tool where one can load all phone partions then 1. read selected partitions 2. browse and load partitions files 3. wipe selected partitions 4. write selected partitions factory reset option both flash mode and meta mode Last edited by okello; 04-07-2021 at 13:40. |
04-08-2021, 01:26 | #97 (permalink) | |
The Following 2 Users Say Thank You to blang For This Useful Post: |
04-08-2021, 19:44 | #98 (permalink) |
Member: 2753245 Status: Offline Thanks Meter: 8 | Hello. Tab Joy 2 (9032z) MetroPCS variant USA. This model not yet supported for unlock by any box or software. Maybe pandora can be first? If need remote testing I am available to offer my device. (skype = [email protected] ) |
04-08-2021, 20:26 | #99 (permalink) | |
04-10-2021, 20:15 | #103 (permalink) |
Member: 1610674 Status: Offline Sonork: 210921 Thanks Meter: 217 | I would suggest you add Samsung Tab. and add Samsung MTK devices Reset frp Network unlock IMEI repair Patch cert Since they are also MTK devices this would make this tool from another world Also add oppo and vivo reset locks without data loss Mi account reset option for Xiaomi devices Auto backup of security partitions before repair IMEI option Backup and restore nvram Force phone to charging mode or reboot after failed operations I know am asking a lot but that is because I believe you can DO IT |
The Following 2 Users Say Thank You to okello For This Useful Post: |
04-10-2021, 21:49 | #104 (permalink) |
Freak Poster Join Date: Feb 2014 Location: Pakistan Age: 38
Member: 2135915 Status: Offline Thanks Meter: 50 | add imei repair for this model Brand : Oppo Model : A31 (CPH2015) Operation : Read Info Connection Mode : BROM (Hold Key for BROM Mode) Hold VOL UP + DOWN and connect USB Cable. Some phone may have different key combination for BROM mode. Waiting for device in BROM mode... Port: COM24 Port Name: MediaTek USB Port (COM24) Path: \\?\usb#vid_0e8d&pid_0003#6&25b4a8de&0&2#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Chipset: 0x0766, [MT6765] Hardware Info: 0x8A00, 0xCA00, 0x00 SecureBoot: True SLA: False DA Auth: True Disabling WatchDog... - Success Sending Payload data... - Payload sent Initiating Control Transfer... - Done Waiting for result... - Result: 0xA1A2A3A4 Disable Auth Success Waiting for Phone in Flash Mode... Connect Power Off phone within 30 secs... Port : MediaTek USB Port (COM24) Connected to BROM. Sending Download Agent... connect DA end stage: 2, enable DRAM in 1st DA: 0 Connected to Download Agent.. Syncing with Target... Reading Partition Table... Storage : eMMC Reading Device Information... Manufacturer : OPPO Build Flavor : full_oppo6765_19581-user Build Desc. : full_oppo6765_19581-user 9 PPR1.180610.011 eng.root.20201217.223505 release-keys Android Ver. : 9 Patch Level : 2021-01-05 Platform : MT6765 Board : oppo6765_19581 Platform : mt6765 Platform : MT6765 Board : oppo6765_19581 Platform : mt6765 Userdata is NOT ENCRYPTED |
04-12-2021, 07:01 | #105 (permalink) |
Member: 1610674 Status: Offline Sonork: 210921 Thanks Meter: 217 | nokia 2.4 error 3 if possible add online minor updates to fix some bugs than waiting for updates many phones still giving error and working fine with other tools |
