03-26-2023, 00:27 | #1 (permalink) |
Freak Poster Join Date: Sep 2015 Location: Lombok
Member: 2465890 Status: Offline Thanks Meter: 176 | Vivo Y77 5G dead after read info Switch virtual port to NONE... OK Connect Type-C to HUB... OK Host Power On... OK Connect phone in PRELOADER Mode Waiting for device... OK Driver: [MediaTek Inc.,wdm_usb,MediaTek PreLoader USB VCOM_V1633 (Android),usb2ser.sys,3.0.1504.0] Device found at COM7 [PRELOADER] Open port... OK Send start cmd... OK Get HW code from device... 0989 Get sec config... OK [00000005] Active sec flags: [SBC DAA] Get HW & SW version from device... OK HW VER: CA00, SW VER: 0000, HW SUB CODE: 8A00 LibUSB installed Detect chip [MT6833] Library Version [2] Select platform... OK Init BROM... OK Force Charge... OK Disable WatchDog Timer... OK Reopen port for libver2... OK Preloader exist. Skip connection verification. Get ME ID... OK ME_ID = 0xE7020DEC, 0x157CBD15, 0xBB3F9708, 0xCB3305A8 Load DownloadAgent... OK Search DA... OK [11] Send bootloader... OK Start bootloader... OK Wait for answer from bootloader... OK Send SYNC signal... OK Setup device enviroment... OK Setup device parametres... OK Receive DA SYNC signal... OK Set DA parametres... OK Get device connection agent... [PRELOADER] Preloader alive. Skip initializing external RAM Get device info... OK UFS CID (FW VER): KM8F9001JM-B813 (0200) Advanced Bypass Security... OK Send preloader... OK Load DownloadAgent... OK Search DA... OK [14] Send 2nd DA... OK Get device info... OK UFS INFO: UFS_CID : KM8F9001JM-B813 UFS_FWVER : 0200 BLOCK_SIZE: 0x0000001000 (4,00Kb) UFS_LU0 : 0x0000400000 (4,00Mb) UFS_LU1 : 0x0000400000 (4,00Mb) UFS_LU2 : 0x3B96000000 (238,34Gb) RAM INFO: INT_SRAM: 0x0000070000 (448,00Kb) EXT_RAM : 0x0100000000 (4,00Gb) Checking USB status... USB_HIGH_SPEED Read partitions info from phone... error(STATUS_PARTITION_TBL_NOT_EXIST) |
