Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L )
Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) Nokia Legacy Models Like 1011, 1610, 211x, 2x20, 6050, 3110, 8110, NKxxx , 2100, 3210, 3310, 3330, 3410, 5110, 5210, 5510, 6110, 6150, 6210, 6250, 7110, 8210, 8250, 8850 also 9110 & 9210
Old 09-05-2000, 08:49   #1 (permalink)
Crazy Poster
Member: 1010
Post 3210 v5.36, 5110 v5.29 HELP
Please help me with v5.36
I read all topics and replies about 5.36
I tryed to unlock 3210 v5.36, 5110 v5.29, and nothing.
I tried solution with shunt 5-6-7, and pin 5 to GDN through 10K and nothing.
I pressed read me, then coneected p5 of 24c128 to gnd through 10K, then pressed read me, then open all for 5 times,then disconnected pin5, pressed open all, but lock 1 is closed anyway. I tried for about 20 times with different sw: nokiatool v33,v34,v5.36 by turkey. I think problem is with sw. I mean that i have maybe demo or fake version, but i used this sw for 3210 5.31 and 5110 5.28. If you have working and tested sw or any idea, please send me.
mobile*******@mail.ru
Old 09-05-2000, 10:01   #2 (permalink)
X-Shadow's Avatar
Member: 871
Thanks Meter: 602
Post
Hello Man,
Thank Dagger for solution described below...
This is no joke, take this seriously ok?
Use ordinary MBUS cable (no 10K modification)
Open the unit and connect the MBUS and power
it on. Press 'Read Me', you should have a
proper reading...
If all ok above, do next step below...
Follow this because I am not kidding although
this sounds a little funny...
Get needle from your wife's or mother's
cabinet. If you don't have a needle, a
metallic prod would do or even a stainless
steal fork for that matter!
Remove right shoe and socks (this is funny).
Put your feet flat on the floor.
Now, connect needle to pin5 only, leave other
pins as is, do not mind them, we are only
interested in PIN5.
Your bare fingers must be touching the needle
or the metallic part of the prod if you use
prod.
Now with the needle connected to pin5 and
to your fingers, click 'Read ME' again. You
will see funny IMEI like 5.28 and 5.31
before. Now click 'Open All' twice, then
remove the needle and click open all one
more time and now all locks are opened!
It works 100% I tested it, but I did not
remove my ***** and socks. It is very humid
here in my country so I don't need to do
that. Maybe in your country is cold, so you
have to remove ***** to get Earth Ground.
The 10K solution I also tried, but it did
not work for me. Maybe 10K is not enough or
to much Resistance compared to human body,
Wildswan talk about this before.
So far I unlocked 8 3210 5.36 and 2 5110 5.29
with this solution and has no 'Contact
Service' problem yet. I also locked again
one of my 3210 5.31 with 4 locks and tried
to unlock it again uing method discovered
by Dagger above and it also worked!
Best Regards,
X-Shadow
Old 09-05-2000, 10:33   #3 (permalink)
Crazy Poster
Member: 1010
Post
Thanks, It's really funny.
But first, when i touched the floor by my ***** foot i see real imei.
I tried this. Imagine, what my customers think about me, when they see me with one ***** food,trying to do something with their phone. I told one person to come for his phone at 17.00 yesterday. And i really forgot for this time, trying this method. You can imagine what he saw in 17.00.:-).cool. Ok. I'll try again.
Tell me does nokia tool v33 work with v5.36 or i must use another sw ?
Old 09-05-2000, 15:28   #4 (permalink)
Crazy Poster
Member: 1010
Smile
It really works for me.
100% working.
Old 09-05-2000, 16:18   #5 (permalink)
Member: 1292
Question
I had contact serv. by this way !
how to fix it please
Old 09-05-2000, 18:19   #6 (permalink)
Member: 1714
Post
Hi. I tryed to unlock 3210 v5.36 by 10k method. First nokia was successfuly unlocked. But second said "Contact Service" ... and now its dead Any ideas how to fix this prosblem?
Old 09-05-2000, 21:29   #7 (permalink)
Member: 2004
Post
Hello everyone
Thanks to Dagger I opened 3 nokia 3210. But I had also problems with method of foot. But I used this method and it worked well: Take two cables. the first ones end connect to steel cover of your PC and the other end take in to your hand. Then use the second cable. The first end put in your ***** (I am really not joking) and the other end connect to pin 5. Now you can feel in your ***** the power from your phone, if not, you are not good grounded. You have to feel it to unblock successfully your phone. Now click 5 times on unlock and then disconnect the cable from pin 5 and again click on unlock. The lock should be opened. Remember, when you are connected to pin 5 you must see funny imei something like this 656565656665. Thats all. I wish it will help you
Old 09-05-2000, 22:29   #8 (permalink)
Member: 1485
Post
How exactly do I have to open the phone?
Ne1 ne pics?
Thanks
Kane
Old 09-06-2000, 00:29   #9 (permalink)
Member: 1689
Wink
O.K. solution with needle on pin 5 is realy working, only problem is to get good grounded. I have discovered easier solution (no cabels in *****, no feet on cold ground).
Open the phone remove display, put MB back and then that metalic part on it. conect baterie and cable. Read the phone in Nokia Tool. then use needle to pin 5 and touch with other finger that metalic part (it is realy grounded) it works better if your fingers are little bit wet. read phone again. original IMEI must be like 656565..., 6:16:16:..... then clic 5x open, disconect needle and click open again.
I have unlocked with this metod about 15 3210s and I get no Contact service
Good luck!
Honza
Old 09-06-2000, 10:23   #10 (permalink)
Member: 809
Unhappy
I´m sorry but you must be joking,(cable in your *****!!!!)
Have you ever heard of differencial of fase?? then you know what can happen???
As well the difference of ground(gnd)and the earth´s ground can be different..
Just to let you know that this can be verry dangerous...do not try this...
Old 09-06-2000, 21:47   #11 (permalink)
Member: 2027
Thanks Meter: 5
Post
Hello to all! With what program unlock the 3210? Version 033 or 034?
Thanks
Old 09-07-2000, 08:01   #12 (permalink)
Member: 1971
Post
Well I think I started with putting a wire into my ***** and with my leg I touch the computer, that sollution is the only one working for me couse I ve already tried connecting to 100% ground.. and I see funny imei but the phone wont unlock.. every1 has its own method.. but still if u re unsuccesfull in unlocking the phone this way.. click READ ME as long as u dont see different funny IMEI as the one before.. I ve noticed that if 656656565 doesnt work smth like 8:7:35:8: will work almost for sure but still some wont unlock then Im looking for 6576565656 (only diference is in the 3rd number-->7) if I get this IMEI phone will unlock for sure
bye jure
Old 09-08-2000, 16:00   #13 (permalink)
Member: 892
Thanks Meter: 2
Question
Hi Unidencek,
ground is not the problem!!! as you said.
I unlocked at least 30 3210 Ver. 5.36 but as you said - some woun´t unlock!!!
HOW DO YOU GET "657"??? I read phone so long till prog. says cannot open. I only get 6565656.... Thanx
3210 5.36 Problem (CS) Please help! ggyano Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 12-31-2001 08:28
Help for unlocking 5110 V5.29 SashaM Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 01-10-2001 16:21
help please me with mine 5110 v5.29 magsat Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 01-07-2001 21:14
5110 5.29 help!!! delta Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 13 10-22-2000 08:31
5110 v5.28 & 3210 v 5.36 by cabel only AMTX99 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 10-03-2000 12:22
Page generated in 0.22550 seconds with 9 queries
