05-16-2002, 05:46 | #1 (permalink) |
Junior Member Join Date: Dec 2001 Location: London
Member: 7924 Status: Offline Thanks Meter: 0 | 8210 - 8250 wont work Can anyone help or suggest anything? Thanks Last edited by Burnah_; 05-16-2002 at 05:49. |
05-16-2002, 06:34 | #3 (permalink) |
Member: 7924 Status: Offline Thanks Meter: 0 | Still same problem . Maybe my flash files are dodgy? The first file I flash is 1,900,544 bytes and teh eeprom is 196,608 bytes, that sound right? Also, after I flash the first file using Knock22 I then have to use Rolis 4.77 to flash the eeprom because it wont work in Knock22, and when I flash in Rolis it says mobile type is wrong, but flashes it still ? Any help ? Thanks |
05-17-2002, 02:36 | #6 (permalink) |
No Life Poster Join Date: Jul 2001 Location: London, UK
Member: 5324 Status: Offline Thanks Meter: 7 | @burnah_ u can boot your pc in safe mode and use nk_calc u should just use rolls 4.71/4.77/4.78b6 do all flashing in rolls, do mcu+ppm (v3.12) latest ver not always work properley also after everything i.e flash ppm/mcu and flash eeprom with 8250 virgin eeprom, the reboot safe mode and use nk_calc to do imei, sp data, and auth id. then make sure you do a factory reset i.e restore factory settings this last thing should clear your problem email me if your still stuck regards nick |
05-17-2002, 08:56 | #7 (permalink) |
Junior Member Join Date: May 2002
Member: 11972 Status: Offline Thanks Meter: 0 | I done mine on the 14/05/02, flashed phone with 8250 MCU and PPM using NWorkshop, then used Rolis to flash Virgin EEprom to phone from 3d0000 to 400000, switched to M2Bus and used Eeprom tools to update FAID, IMEI and Unlock SP's, full factory, and have no probs. |
05-17-2002, 14:40 | #8 (permalink) |
Member: 7924 Status: Offline Thanks Meter: 0 | Thanks for all the replies. nk_calc still wont work in safe mode, get same error 'bad connection', but the cablse work in other software ? But I finally done it , ty you everyone , I had to use 8250mcu+ppm version 5.04 though, couldnt find 3.12 but would very much appriciate it if some one could send me it? Thanks Update* Has the ringtone name problem now, where it says type 1 type 2 etc, not to much of a biggie, any suggestions? And have also ran into that same problem with a 3310, any suggestions there? I first flash 3315 full flash (2MB) then flash 3310 v5.47ppm and mcu, then change imei/unlock/update faid. Last edited by Burnah_; 05-17-2002 at 15:44. |
8250 wont hold charge | emmerdale | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-23-2004 07:12 |
8210 -> 8250 | Maniac | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 02-18-2002 02:44 |
** Nokia Released new 8210, 8250 & 8850 Products Versions. 8Feb2002 ** | AboAli | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 12 | 02-11-2002 13:18 |
** Nokia Released new 8210, 8250 & 8850 Products Versions. 8Feb2002 ** | AboAli | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 02-08-2002 17:45 |
8210/8250 | PhoeniX | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 07-12-2001 03:53 |
