07-04-2001, 03:17 | #16 (permalink) | |
Freak Poster Join Date: Feb 2001 Location: Bacolod, Philippines
Member: 3360 Status: Offline Thanks Meter: 4 | Quote:
Let's take the Standard alert tone (Morse code for "M") as an example (using the 5110v5.30C flash): 5519, 400A, 5519, 400A So it sounds like "dat-dat" 5519 - is a "dat" with a duration of 19 400A - is a pause with a duration of 0C We could change it to: 550C, 400A, 5526, 400A So it sounds like "dit-dat" Take note that we subtracted hex 0D from the first 5519 and added it to the second 5519 to compensate the values so we wont have a contact service message. Here's a more interesting one. Change the Standard alert tone (5519,400A, 5519,400A) to something like this: 5B19, 4005, 4F19, 400F So it sounds like high-note-dat, low-note-dat Or to something like: 4C0C, 4005, 5E25, 400F So it sounds like low-note-dit, high-note-dat Notice that we subtracted duration values from the first pause and add it to the next pause, and so with the first tone to the second tone. Sometimes I get an error when I subtract values from the pause and add it to the tone. Or vice versa. It won't work. So the following won't work in changing Special alert (morse code for "SMS"): 5A0C,400C,5A0C,400C,0AFE,5A0C,4025, 0A01,5A25,400C,5A25,4025,0AFE, 5A0C,400C,5A0C,400C,5A0C That sounds like: dit-dit-dit dat-dat dit-dit-dit "5A0C" is a "dit" with a duration of 0C "5A25" is a "dat" with a duration of 25 "400C" is a pause with a duration of 0C "4025" is a pause with a duration of 25 "0AFE" is.... I don't know what this means, let me know Into a variation of "Let's go": 5A0C,4025,5A0C,4025,0AFE, 5A0C,400C,0A01,5A0C,400C,5A0C,400C,0AFE,5A0C,4025, 5A0C,4025,5A0C That sounds like: dit-dit dit-dit-dit-dit dit-dit "5A0C" is a "dit" with a duration of 0C "400C" is a pause with a duration of 0C "4025" is a pause with a duration of 25 "0AFE" is.... I don't know what this means, let me know It wont work because we subtract values from pause and add it to the tone. So that's that. I'm still studying the behaviour for the default ringtones. Sure I can change some values without incurring a "Contact Service" but the tones won't make any sense. Anyway, I would know who reads this forum in my area when I start hearing a different alert tone around here. P.S. If you find some info here to be interesting, I only ask one thing: please rate me BR | |
07-05-2001, 02:50 | #18 (permalink) | |
As always, before tinkering with your phone flash, make a full backup of your phone flash if you haven't yet. Let's assume you don't have a full backup of your phone flash. 1. Read the flash address 00200000 to 00600000. 2. Copy the \flasher\flash.out to \nk_files\6210full.fls 3. Use a hex editor (I suggest Hexworks), open the \nk_files\6210full.fls and do the following to obtain a full flash without the EEPROM: WARNING: If you notice the file contains FF00,FF00 from beginning to end, DO NOT PROCEED because this is a bad read flash. 3.1 Go to address 3FC000 (this is equivalent to flash address 005FC000) 3.2 Press Shift-Ctrl-Home. This will highlight the data from offset 00000000 to 003FC000. Release the keys. 3.3 Press Ctrl-C. This will copy the highlighted data to the clipboard or memory. 3.4 Press Ctrl-N. This will create an empty file. 3.5 Press Ctrl-V. you will be asked "Are you sure you want to insert?", select "Ok". This will copy the previously highlighted data to the new file. 3.6 Save the file as "my6210.fls" 4. Make a copy of the flash that contains the alert tones. 4.1 Still using the hex editor, open the file "my6210.fls" 4.2 Go to offset 350000. Press Shift-Ctrl-Home. This will highlight the data from offset 00000000 to 003FC000. Release the keys. 4.3 Press Del. You will be asked "Are you sure you want to delete?". Press "Ok". This will delete the data from 0 to 350000. 4.4 Go to offset 10000. Press Shift-Ctrl-End. This will highlight the data from offset 10000 to the end of file. 4.5 Press Del. You will be asked "Are you sure you want to delete?". Press "Ok". This will leave you a 64k data from 0 to 10000 (which is equivalent to flash address 00550000 to 00560000). 4.6 Save the file as \nk_files\6210al.fls 5. Copy \nk_files\6210al.fls to \nk_files\alert.fls 6. Open the \nk_files\alert.fls with a hex editor (I use Hexworks). 7. Use the search string "8005020A01". First stop should be the Special alert tone. You will notice that there's "SMSS.......S.p.e.c.i.a.l" before it. Pressing F3 will take you to the next found string. This is the Standard alert. You will notice that there's "SMS.......S.t.a.n.d.a.r.d" before it. Again pressing F3 will take you to the next found string. This is the Ascending alert. You will notice that there's "SMSL.......L.o.n.g. .l.o.u.d" before it. Don't forget when you flash it back, you should use alert.fls as source and the address should be 00550000. Assuming you have flashed it back to the correct address and it shows a "Contact Service", you may have incorrectly modified your alert tone. If this happens, proceed to number 5. If you want to flash it back to its original alert tones, flash it back with 6210al.fls at address 00550000. But if it still has a Contact Service, flash it back with a my6210.fls starting from address 00200000. This should restore your original flash without the EEPROM part. This procedure is a little bit for advanced flasher users. If you don't know what you're doing, don't try it out. You have yourself to blame if something pukes up. Hmmm... I guess few people are interested in what I'm posting here. Out of more than 100 readers since my first posting in this thread, only 2 person rated me. Oh well, all I'm asking is: rate me please ----------------- Misqouted qoutes: "Don't judge the book without its cover" "Birds flock together on the same feather" "Don't cross the bridge when you get there" "There's no water under the bridge" | |
07-05-2001, 12:34 | #19 (permalink) |
Crazy Poster Join Date: Feb 2001 Location: Westcoast, Poland
Member: 3299 Status: Offline Thanks Meter: 0 | I've tryed to do this like that : 1.make a full backup 002 to 006 (6210) 2.edit with hexworkshop and change the SMS alert 3.try to correct checksums with NK1.2 to avoid Contact Service 4.put flash back to phone 5.works fine Ice Dragon: does point 3 make any sense? <FONT COLOR="#ffff00" SIZE="1">[ 05 July 2001 13:38: Message edited 3 times, lastly by nuggie ]</font> |
07-06-2001, 02:07 | #20 (permalink) | |
I did that already but it always take a long wait to write the whole modified flash back to the phone. With a 5110v530C flash, I also tried cutting the first part of the modified flash (flash address 00200000-00210000), write it back to the phone, then cut the last part of the modified flash (002F0000-00300000) back to the phone so it would take a much lesser time. The one I posted earlier is also to let our members reader learn a little bit about the alert and ring tones in the flash, and the possibility of changing them. Although I believe that our members here know more than I do. Cheers to you... and best regards to all <FONT COLOR="#ffff00" SIZE="1">[ 06 July 2001 03:10: Message edited 1 time, lastly by Ice Dragon ]</font> | |
07-06-2001, 14:56 | #21 (permalink) |
Freak Poster Join Date: Jan 2001 Location: I.C., R.P.
Member: 3165 Status: Offline Thanks Meter: 0 | Man, thanks a lot for the values. I'll try it. And about the word addition information. I'll try to make a workaround on this if I have enough time. I've been off the internet for a time. Thanks a lot man. You're great. Regards, aCe |
07-14-2001, 19:23 | #23 (permalink) |
Member: 3299 Status: Offline Thanks Meter: 0 | Ice Dragon: Look here at the ringtone info. web page <FONT COLOR="#ffff00" SIZE="1">[ 14 July 2001 20:26: Message edited 2 times, lastly by nuggie ]</font> |
07-23-2001, 02:32 | #25 (permalink) | |
First stop should be the Special alert tone. You will notice that previously the tones have 5A0C, 400C, 5A25, 400C values. With the 3310, it uses the 5B0C, 400C, 5A25, 400c values. "5B0C" is a "dit" with a duration of 0C "5B25" is a "dat" with a duration of 25 "400C" is a pause with a duration of 0C "4025" is a pause with a duration of 25 Pressing F3 will take you to the next found string. This is the Standard alert. It uses the 5619, 400A, 5618, 400A values. "5619" is a "dit" with a duration of 19 "400A" is a pause with a duration of 0A Again pressing F3 will take you to the next found string. This is the Ascending alert. It uses the 5B0C, 400C, 5B25, 400C values. "5B0C" is a "dit" with a duration of 0C "5B25" is a "dat" with a duration of 25 "400C" is a pause with a duration of 0C "4025" is a pause with a duration of 25 The alert tones on the 3310 reside in the MCU part of the full flash. Best regards and cheers... <FONT COLOR="#ffff00" SIZE="1">[ 23 July 2001 03:45: Message edited 1 time, lastly by Ice Dragon ]</font> | |
07-23-2001, 15:59 | #26 (permalink) |
Junior Member Join Date: Jun 2001 Location: Mozambique
Member: 5055 Status: Offline Thanks Meter: 0 | Does anyone have good Standard and Special Alert Tones, for 61xx and know how to change them? Ice Dragon, thanks for posting the info, on this issue, I'm a bit new to this, but definetly I'm tired of the current alert tones. Thanks, Pm |
07-26-2001, 01:48 | #28 (permalink) |
Junior Member Join Date: Jul 2001 Location: Wolverhampton - UK
Member: 5468 Status: Offline Thanks Meter: 0 | Ice you are a top man i changed my standard alert on my 3210 to the one posted on here and now everyone is buggin me to do it for them because they all like it so much, once again well done and congrats for findin this out |
new zong with tourch can,t be unlock | pakmobiles | FuriousGold | 3 | 03-29-2010 16:26 |
can infinty informe me if possible | ayoub_gsm | Infinity-Box | 2 | 03-29-2010 14:25 |
can i unlock lg gb 220 | mobi-herc | FuriousGold | 1 | 03-29-2010 10:52 |
can ust-pro informe me if possible unlock this mobile???? | ayoub_gsm | UST Pro II | 0 | 03-29-2010 10:23 |
C60 v12 can read but can,t write flash and can,t unlock!!! | moldovan | E-Gold Based Phones | 3 | 01-15-2004 11:49 |
