06-28-2002, 02:32 | #1 (permalink) |
Freak Poster Join Date: Apr 2002 Location: Nokia Age: 44
Member: 11395 Status: Offline Thanks Meter: 3 | 8250 no network!! I tried using many programs to fix it, but no luck.. I use MBUS, Flasher cable, Knok-Ph, EEprom tools 3.1 by b-phreaks, Nokia tool 1.8 by Rolis, Nokia tool 3.21 by Jordik... Any solution?? Thanks all.. |
06-29-2002, 13:26 | #3 (permalink) |
Member: 11395 Status: Offline Thanks Meter: 3 | Yes I did, I did everything but no luck.. I tried to flash the mobile with an unmodified PPM, it work 100% ok with full network, but with the modified PPM = no network... Help please.. |
06-30-2002, 02:02 | #4 (permalink) |
Member: 11395 Status: Offline Thanks Meter: 3 | OK guys, the problem is solved.. I followed the following steps: 1. Use PPMCutter to cut and save the PPM file it as a flash file (PPMFile.g --> PPMFile.fls). 2. Use FLashTone 2.05 to convert the MCU file to flash file (MCUfile.mcu --> MCUfile.fls) 3. Use Dejan_to_Wintesla convertor to convert both the MCU & PPM files into Wintesla files. 4. Use Knok Phoenix to convert the TWO Wintesla file to ONE flash file. 5. Use PPMManager 0.91 to update all PPM CRC's, then save the file. 6. Flash the file into the mobile, continue in the normal procedure (Set IMEI, Clear SP locks, Calculate FAID... etc..). I don't know if there is another simpler steps, but I know these steps works 100%. P.S: I think we can skip steps 3 & 4, and just flash the two files (MCU & PPM) after updating the PPM CRC's using PPMManager.. The mobile is working now 100% with full network and custom PPM with Arabic Language.. Thanks for posting.. Best wishes.. Fadi79 |
06-30-2002, 11:30 | #5 (permalink) |
Junior Member Join Date: May 2002 Location: Russia Age: 45
Member: 12292 Status: Offline Thanks Meter: 0 | How to fix 8250(8210) no network after upgrade? Hi all, I flashed my 8250 with a custom PPM ver. 5.00 , but the phone can't see the network!! Can I fix it using this programs : EEprom tools 3.1, Nokia tool 1.8 by Rolis. Or I need to make this steps anyway? 1. Use PPMCutter to cut and save the PPM file it as a flash file (PPMFile.g --> PPMFile.fls). 2. Use FLashTone 2.05 to convert the MCU file to flash file (MCUfile.mcu --> MCUfile.fls) 3. Use Dejan_to_Wintesla convertor to convert both the MCU & PPM files into Wintesla files. 4. Use Knok Phoenix to convert the TWO Wintesla file to ONE flash file. 5. Use PPMManager 0.91 to update all PPM CRC's, then save the file. |
07-07-2002, 21:38 | #7 (permalink) |
Product Supporter Join Date: Jan 2002 Location: Philippines
Member: 8303 Status: Offline Thanks Meter: 127 | want to know whats causing the problem? the problem is, the last 8 bytes of your PPM are invalid, everytime you modify full flashes, dont forget to correct checksums using PPM Manager 0.91, otherwise, if you dont correct checksums, you can use logger to calculate FAiD. |
07-07-2002, 21:54 | #8 (permalink) |
Member: 12292 Status: Offline Thanks Meter: 0 | How to make it correctly? To correct checksums using PPM Manager 0.91 I need PPM only or MCU+PPM together in one flash? Give me PPM Manager 0.91 or link pls... |
11-17-2002, 22:49 | #9 (permalink) |
Junior Member Join Date: Feb 2002 Location: russia
Member: 9474 Status: Offline Thanks Meter: 0 | 8250 solution The easiest way to solve 8250 flash file problem is to use knock by phoenix, set flash file as source and fix all of you can. Knock will fix four bytes and that's all! 001CFFFC: 1A 6D 001CFFFD: 9D 6D 001CFFFE: C7 61 001CFFFF: 9D 78 ILYA [email protected] |
8250 No Network Found! | khan6653 | Nokia Hardware & Hardware Repair | 0 | 07-05-2008 06:57 |
8250 no network with strange imei | baraka42 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 05-24-2004 10:46 |
wired 8250 rssi -56 no network. | baraka42 | Nokia Hardware & Hardware Repair | 3 | 03-01-2004 19:04 |
8250 no network | VinhHai | Nokia Hardware & Hardware Repair | 8 | 10-20-2003 13:54 |
nokia phones with network+full signal then NO SIGNAL AND NO NETWORK NAME .!! | makona | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 07-22-2002 15:20 |
