08-13-2001, 20:06 | #1 (permalink) |
Junior Member Join Date: Aug 2001 Location: Central England
Member: 5766 Status: Offline Thanks Meter: 0 | Problems unlocking 3310's v 4.24 and beyond Please help as i am most puzzled. Does it have something to do with the eeproms? Please e-mail me if you have the answer. [ 13 August 2001: Message edited by: The Locksmith ]</p> |
08-21-2001, 10:32 | #2 (permalink) |
Freak Poster Join Date: Apr 2001 Location: Switzerland Age: 46
Member: 4172 Status: Offline Thanks Meter: 0 | maybe the eeprom of phone is bad, make sure if you have used the same boot.bin and f_loader, check cable connectors [ 21 August 2001: Message edited by: Neo's ]</p> |
08-28-2001, 10:59 | #3 (permalink) |
No Life Poster Join Date: Sep 2000 Location: Philippines
Member: 2034 Status: Offline Thanks Meter: 24 | Hi man, Try checking first on your connection pins of the 3310 unlock clip, you must check it in order to determine if they are connected well. If they are checked and found ok next is the flasher cable itself, in this case the flasher cable may have improperly attached, if its not the case then go to the unit itself. Check the phones power switch sometimes 3310's power switch are mostly the problem. <br />I dont think that its your boot.bin and f_loader.bin that has the problem. If you persist that its the one your pointing to be the main source of your delemma email me and ill send you loaders courtesy of d_bug. REGARDS Allen<br />+639173427696/+639192310127<br /><a href="http://visnet_dd.tripod.com" target="_blank">Visual Network Database Developers</a> |
08-29-2001, 07:46 | #5 (permalink) |
Freak Poster Join Date: Jan 2001 Location: I.C., R.P.
Member: 3165 Status: Offline Thanks Meter: 0 | Try refreshing your copy of flasher.com, f_loader.bin, and boot.bin coz this usually solves that problem. That is assuming of course that your cable is AOK. [quote] <br />hi <br />the bad ram erorr <br />it mean the flash ic ram is damedge<br />and the phone will no longer work <br />sorry about that <br />regards <br /><hr></blockquote> It doesn't necessarily mean that the phone itself is damaged. You can get this kind of error if your cable -> phone contacts are not good. <br />If you want to, try using Jethro v6 instead. That way, you'll know if its a hardware or software problem. <br />Regards, aCe |
08-30-2001, 03:49 | #6 (permalink) |
No Life Poster Join Date: Oct 1999 Location: Hong Kong
Member: 596 Status: Offline Sonork: 100.33096 Thanks Meter: 514 | Hello<br />As my experiences it usually caused by the wrong flash loader , try to change it and see. <img src="smile.gif" border="0"> good luck! |
Big problem with firmware 2.4 b and Nokia H3G Italy | porcellino | YESSIM | 2 | 07-26-2008 06:41 |
3510 4.24 and cheap flasher | erogsm | Nokia Digital Core Technology 4 ( DCT-4 ) | 16 | 02-26-2004 14:00 |
How can I unlock 3510 V 4.24 ? | CezaricaGSM | Nokia Digital Core Technology 4 ( DCT-4 ) | 0 | 04-06-2003 23:12 |
Unlock Nokia 3510 4.24 | laxxe | Nokia Digital Core Technology 4 ( DCT-4 ) | 12 | 03-05-2003 20:14 |
Problems unlocking 3310's v 4.24 and beyond | The Locksmith | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 08-13-2001 20:19 |
