03-17-2002, 07:22 | #1 (permalink) |
No Life Poster Join Date: Jun 2001 Location: Portugal Age: 48
Member: 4975 Status: Offline Thanks Meter: 612 | Signal Drop Solution for 6210 for ages losing its signal all the time. The problems i had was the signal, would just drop to nothing. Also during a call if you moved the phone around, the signal would break up. I have sussed out the cause of it now. On the back of the phone is a antenna socket (With a rubber bung in it). This socket has a changeover type thing in it which disconnects, the internal antenna when you plug something into it. The problem on my phone was the changover part playing up. As i never use the socket i just soldered a thin piece of wire, to the top and bottom pins on the antenna socket and it cured all my problems If you have a look at the attached picture, you will see two highlighted points with a red dot. You need to solder a thin piece of wire to link these two points. Keep the wire as thin as possible and remember, to use a small soldering iron. It is very easy to f**k, the phone up if you poke the soldering iron in the wrong place. All the little surface mount components have a habit of falling off, the pcb if you get too close to them. Thanks to Dave Schwantzdownload solution and picture Last edited by schwantz; 03-17-2002 at 07:25. |
03-17-2002, 08:03 | #2 (permalink) |
No Life Poster Join Date: Dec 2001
Member: 8030 Status: Offline Thanks Meter: 3 | cheers Schwantz, I'm giving it a go now - my 6210 has been back to Nokia twice now for this fault - both times they say No Fault Found - hope it works. I'll post back here with results. Cheers, |
03-18-2002, 05:25 | #4 (permalink) |
Freak Poster Join Date: Jun 2001 Location: Hungary-Russia Age: 46
Member: 4894 Status: Offline Thanks Meter: 0 | I have the same problemm with 3310 My 3310 is absolutly new (1month), but after 10 times of flashing/reflashing it began to drop the signal and break the talk sometimes |
k608i signal drops after 1-2 hours, pls, share solution | rey_astrophil | Sony Ericsson Hardware Repair | 1 | 05-21-2008 07:50 |
nokia 1100,2300 perfect solution for dropping signal | noktune_win | Nokia Hardware & Hardware Repair | 2 | 10-14-2006 21:13 |
Drop signal after faid calc. 6210 | fofodaman | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 03-16-2002 12:58 |
Any solution for 6210 "Contact Service"? | ags28 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 07-27-2001 18:11 |
!!! I found solution for 6210 Security Code Problem !!! | Brobble | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 39 | 05-08-2001 09:59 |
