10-02-2004, 14:59 | #3 (permalink) | |
Freak Poster Join Date: Jun 2002 Age: 45
Member: 13373 Status: Offline Thanks Meter: 5 | Quote:
its it If u need something from flash file or software contact me by email here www.geocities.com/nestorenie best regards | |
10-02-2004, 19:26 | #4 (permalink) | |
No Life Poster Join Date: Apr 2003 Location: Bled lekhla
Member: 27291 Status: Offline Thanks Meter: 81 | Quote:
If the serial nuber is OK ,you can revive your phone by flashing IT! If the serial nuber is faulty or doesn't feet As I know ,in this case ,you can't do any thing ! In the featur perhaps !!!!!!! | |
10-02-2004, 21:18 | #7 (permalink) | |
Member: 25806 Status: Offline Sonork: 100.78148 Thanks Meter: 2,915 | Quote:
hi.. This is Mostly Fault in 1100 and 2300 Mobile. SO this is 1000% confirm your IMEI is goes to ????????????4 so u need Griffin Server to Rebuild the IMEI. Read Imei and then send to griffin server. When u read its ASK file first confirm it should be same as original. Otherwise after Rebuild the IMEI your Mobile is Restart after 2min. so if u got this problem so only 1 solution change it UEM chip. Best Regard's Muhammad Tahir www.tech-mobile.net | |
10-02-2004, 21:34 | #8 (permalink) | |
changing IMEI with Griffin ??? | |
10-05-2004, 09:04 | #13 (permalink) | |
10-06-2004, 15:11 | #15 (permalink) |
Member: 25806 Status: Offline Sonork: 100.78148 Thanks Meter: 2,915 | hi... mate just read ask file through Griffin or Twister. This is not free solution u must buy Griffin log the price of 1log is $8 br Muhammad Tahir www.tech-mobile.net Last edited by TaHiR; 10-06-2004 at 15:24. |
Nokia 1100 Problem "sim Not Valid" | !!TOKEN!! | Nokia Hardware & Hardware Repair | 5 | 02-06-2012 22:42 |
how unlock "sim not valid" nokia 3250? | bonab_gsm | Nokia Base Band 5 ( BB-5 ) | 6 | 11-18-2007 09:10 |
N70 "sim Not Valid"-wrote Rpl-still In "sim Not Valid" | zonetrichur | Nokia Base Band 5 ( BB-5 ) | 5 | 10-05-2007 13:52 |
N73 not locked but "SIM NOT VALID" | meisam | MT-BOX | 4 | 08-04-2007 08:26 |
