Old 03-13-2008, 18:00   #1 (permalink)
Member: 77437
Sonork: 100.1582159
Thanks Meter: 93
2760 charger not supported HELP
New Nokia 2760, the phone can charging when the phone is off , but when the phone is on will show ' charger not supported ' is there any solution like 2630 ????? please help
The Following 4 Users Say Thank You to ruwanjk For This Useful Post:
Old 03-13-2008, 18:32   #2 (permalink)
Member: 77437
Sonork: 100.1582159
Thanks Meter: 93
2760 charger not supported solution
this is same like 2630, remove 2205 and phone will work fine, tested with 10 phones
The Following User Says Thank You to ruwanjk For This Useful Post:
Old 03-13-2008, 22:09   #3 (permalink)
nasirahmed's Avatar
Member: 57760
Sonork: 100.1579298
Thanks Meter: 3,510
Can you provide me a pic where the 2205 is on the PCB?
The Following User Says Thank You to nasirahmed For This Useful Post:
Old 04-25-2008, 09:30   #4 (permalink)
rajeshkanna's Avatar
Member: 582515
Thanks Meter: 70
hi guys .. the nokia 2630 charger not supported brand new solution 100% working tested... the link given below
http://forum.gsmhosting.com/vbb/show...t=2630+charger
The Following 5 Users Say Thank You to rajeshkanna For This Useful Post:
Old 07-11-2008, 10:42   #5 (permalink)
Member: 800139
Sonork: papuia
Thanks Meter: 30
2760 chager notsupport
download this file
The Following 4 Users Say Thank You to papuia For This Useful Post:
Old 07-17-2008, 10:50   #6 (permalink)
Member: 50272
Thanks Meter: 37
remove 2205 on phone.
or
battary problem ( after patch unlock ) write pm after patch unlock for charging problem.
and chang battery and try again to charg phone.
The Following User Says Thank You to Secgsm For This Useful Post:
Old 07-17-2008, 10:57   #7 (permalink)
Member: 575576
Thanks Meter: 25
just flash it with high version and its all okey,,then full factory defualts,,,
The Following User Says Thank You to rolly_van For This Useful Post:
Old 09-05-2008, 15:36   #8 (permalink)
suneel's Avatar
Member: 384984
Thanks Meter: 456
remoce this coil your problem solve 10000000000000%%%%%
The Following 21 Users Say Thank You to suneel For This Useful Post:
Old 09-06-2008, 09:07   #9 (permalink)
shakeeldawach's Avatar
Member: 471955
Thanks Meter: 201
good boy
Old 03-26-2009, 16:11   #10 (permalink)
Member: 148908
Thanks Meter: 117
solutions working % try enter code *#7780#
Old 03-26-2009, 16:40   #11 (permalink)
Member: 495453
Thanks Meter: 22
batri canectar ke just upar side watar damaze ke liye chek kar le wahi se charjar not soprt aata hai
Old 05-28-2009, 04:15   #12 (permalink)
..:::YMG:::..'s Avatar
Member: 667126
Sonork: 100.1651201
Thanks Meter: 229
ghanta aata hai ?change the coil in upper pic ?ok bro ?alwaya post working pic?
Old 06-07-2009, 08:16   #13 (permalink)
Member: 295624
Sonork: 100.1667663
Thanks Meter: 30
Talking
gooooooooood job broooooo niceee solution.....................
The Following User Says Thank You to sem_g For This Useful Post:
Old 06-16-2009, 12:15   #14 (permalink)
Member: 342371
Thanks Meter: 73
try this
http://www.4freeimagehost.com/show.p...8820794b8c.jpg
Old 08-14-2009, 20:55   #15 (permalink)
Member: 82113
Thanks Meter: 11
2760 charger not suported
remove this : 100% tested
The Following 7 Users Say Thank You to jose roberto For This Useful Post:
Nokia 6500C Charger not supported help..help pamukelektronik Nokia Hardware & Hardware Repair 49 12-04-2013 23:50
Nokia 2760 charger not supported problem najeebs Nokia Hardware & Hardware Repair 14 04-17-2012 19:44
nokia 7390 charger not supported help!!! watari31 Nokia Base Band 5 ( BB-5 ) 3 04-22-2010 15:28
2760 charger not supported mirza_alamgir Nokia Hardware & Hardware Repair 6 01-29-2010 12:09
2760 charger not supported solution here....... chohansahib Nokia Hardware & Hardware Repair 1 01-29-2010 09:56
Page generated in 0.31825 seconds with 10 queries
