Old 12-02-2005, 07:37   #1 (permalink)
PARMATMA's Avatar
Member: 201107
Sonork: 100.1576954
Thanks Meter: 737
3100 on with ufs not with switch
I hvae 3100 on with ufs not with switch anybody have solution ?
Old 12-02-2005, 14:30   #2 (permalink)
Member: 73144
Thanks Meter: 5
are you get switching voltage on terminal friend?
Old 12-03-2005, 03:28   #3 (permalink)
Member: 82549
same 3650 flash ok with on ufs not with switch
Old 12-03-2005, 05:38   #4 (permalink)
~:Sujyot GSM Zone:~'s Avatar
Member: 48238
Sonork: 100.54361
Thanks Meter: 397
Try to change the HELGA . sometimes it is the problem.
Old 12-03-2005, 11:57   #5 (permalink)
Dave.W's Avatar
Member: 7653
Thanks Meter: 823
i think first check ur power switch
right side top pin will be ~3V when ope and fall to 0V when depressed.
another problem u may see is very flat battery.
i put power supply ~4V on the battery for some second (untill current draw is ~650mA) then put in phone and connect charger. it will now charge as normal
Old 12-03-2005, 23:47   #6 (permalink)
Member: 174912
Thanks Meter: 2
If the switch lines are good then just Reflux UPP & UEM.
Old 12-04-2005, 14:56   #7 (permalink)
PARMATMA's Avatar
Member: 201107
Sonork: 100.1576954
Thanks Meter: 737
I change helga and get the result, phone is power on with switch.
Old 12-04-2005, 17:42   #8 (permalink)
rajiv007's Avatar
Member: 78767
Sonork: 100.95137
Thanks Meter: 566
dave.w is 100% right.................
Old 12-17-2005, 09:18   #9 (permalink)
Member: 109794
what is helga. and where is the location in the phone. i have same problem. thanks
Old 12-17-2005, 11:11   #10 (permalink)
Dave.W's Avatar
Member: 7653
Thanks Meter: 823
helga is RF IC (it contain haggar IC you know from dct3 plus other stuffs).
you find that on back side of phone, under the middle cage. it is the only ASIC under that cage
1650 on by ufs not by battery chhoton Nokia Digital Core Technology 4 ( DCT-4 ) 12 10-22-2009 16:29
8210 power ok with ufs ...but with battry not.. kusutm58 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 03-02-2009 20:05
..::nokia 73 power on with cable not with battery::.. HUM Nokia Hardware & Hardware Repair 4 07-19-2008 23:57
6680 power on with cable not with battery unlock & flash Nokia Base Band 5 ( BB-5 ) 2 06-02-2008 21:30
3660 power on w/ ufs not with battery aranaar Nokia Hardware & Hardware Repair 1 02-19-2007 10:06
Page generated in 0.23118 seconds with 9 queries
