02-21-2003, 11:05 | #4 (permalink) |
No Life Poster Join Date: Mar 2001 Location: Some where around the world.
Member: 3845 Status: Offline Thanks Meter: 2 | if pcn 1800mhz no network change 1800 mhz P.A.How about gsm 900mhz it that ok got network?Let me know.Or try to menu setting there manual find find a network let me know the result. Thanks. |
02-22-2003, 04:35 | #6 (permalink) |
Freak Poster Join Date: May 2002 Location: egypt Age: 46
Member: 11466 Status: Offline Thanks Meter: 0 | MAY WAY tested 100% try may way man u have a soluation 1- searck maniualy by network 2- IF u have ( no network found) check that a. a small silver filter under a left PA (this filter is important it have 4 lege a tall one is negative on left and in right 3 leg maybe on of it is not founed chang it b. a black tall filter have 8 legs change it c. a capulare filter in down the colure is wight have a three pass if it broken change it d. anttena swich f. hot in cobba by flux or reballing it when u have a result or have network not access then stoop and move 2 a 2nd part 1- if u have in search maniual not access change PA in right 2- change 2nd PA in left THATS ALL GOOD LUCK replay me a result |
3210 screen fault | BigRich | Nokia Hardware & Hardware Repair | 2 | 03-05-2004 18:47 |
3210 pa for 900mhz and 1800mhz | eureka8888 | Nokia Hardware & Hardware Repair | 1 | 09-22-2002 16:11 |
3210 fault | MrDurst | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 02-14-2002 03:48 |
3210 1800Mhz signal very low | hooi76 | Nokia Hardware & Hardware Repair | 0 | 02-06-2002 14:04 |
3210 Charging fault | Vicky | Nokia Hardware & Hardware Repair | 7 | 12-10-2001 00:49 |
