07-22-2002, 21:39 | #1 (permalink) |
Freak Poster Join Date: Jan 2002 Location: phils.
Member: 8450 Status: Offline Thanks Meter: 14 | 3310/8210/8250 water damage can't switch on but |
07-25-2002, 00:24 | #3 (permalink) |
No Life Poster Join Date: Oct 1999 Location: Hong Kong
Member: 596 Status: Offline Sonork: 100.33096 Thanks Meter: 514 | Hello For this situation you have to check around to sure what's wrong with your phone , for first take out the main board and put it on the test jig , connect the power supply then use scope to check 26 MHZ TCVCXO and 13 MHZ CPU clock , then chcek CCONT if it has 5.v in , if it don't has 26 MHZ generated you must to change the 26 M TCVCXO,if it don't have 13 MHZ cpu clock ,you have to change Hangar and by the way I don't recommand to reflow the I.Cs rebuild the soldering ball will be much better to ensure that your I.C are without bad conntact ...etc.. goodluck! |
07-25-2002, 03:46 | #4 (permalink) |
Junior Member Join Date: Jul 2002 Age: 52
Member: 13520 Status: Offline Thanks Meter: 0 | I had the same prob with a 3310 it fell down the toilet and would not switch on, i left it for a couple of days and just switched it on for curiosity and it came on, only was that the signal had gone. |
07-25-2002, 14:40 | #6 (permalink) |
Freak Poster Join Date: Jun 2000
Member: 1623 Status: Offline Thanks Meter: 1 | something is wrong. If TCVCXO doesn't work then phone doesn't show charhing bar because CPU is updating the charging bar. I think it is line problem.in 3310 there is a diode near ccont which connected to the near the power switch.There are 1 resistor and 1 capacitor pair.1 cm below power switch and right side. Measure this line whether or not short circuit.It must be short circuit.If it doesn't solder a wire from this diode to this circuit. Best Regards... |
07-25-2002, 14:48 | #7 (permalink) |
Member: 596 Status: Offline Sonork: 100.33096 Thanks Meter: 514 | Yes, you are right nightxyz there is an I.C right side of CPU is the charging controler if it's short circuit , it will show changing bar, but what I mentioned just for the normal water fall or damaged phone repairing |
07-26-2002, 01:23 | #9 (permalink) |
No Life Poster Join Date: Mar 2002 Location: AnyClient Age: 44
Member: 10485 Status: Offline Sonork: 100.66876 Thanks Meter: 396 | It cause by schemes under CPU All you have done is connect pin E2 of CPU to V360, I have repair many phone like that. Mail me at [email protected] |
07-29-2002, 10:43 | #14 (permalink) | |
No Life Poster Join Date: Mar 2000 Location: inside NOKIA phone Age: 58
Member: 1060 Status: Offline Thanks Meter: 10 | Re: 3310/8210/8250 water damage can't switch on but dragories IF phone showing running bar after you plug your charger, it mena, 50% you get lucky , must parts ok! now, you test phone. if you have test jig, good. if not, ok.. open phone, put a 10K ohm (103) resistor between BSI to GND, then give 4.2 V to phone. then VB+ put a 100 ohm resistor , to connect to Btemp pin for 1 sec . your phone must power up. try to press key 3 6 9 # first, look at those key working or not ! if not, MCU line E2 this pin has problem or PCB link cut ! then you go to check R374 and R118, it must have 3.7V , if not, check V360 , it line come from MCU ROW 4, to UI key 3 6 9 # then V360, then R374 , then power switch ! B.R. Willy Quote:
07-29-2002, 10:57 | #15 (permalink) | |
Member: 1060 Status: Offline Thanks Meter: 10 | gsmsalers, you are RIGHT please also check Flash ROM and RAM power supply . when you go to flash 3310 or 8210 phone, almost all NOKIA DCT3 phone, PC have to send 2 set code to MCU, then MCU will put it on RAM, and RUN it . This RAM at 8210 , it come together in D210 (flash rom 16M*16/ RAM 2M*16 ), i been remove flash rom, and try flash phone. Wintesla report "EXT. RAM Fail" , then i will know CPU working ! it is becasue, we do not know in CPU side or flash rom side which one fault, so i always remove flash rom before i remove CPU B.R. Willy Quote:
n95 water damage-can't flash- lcd just on then hang.... | Formingus | Nokia Hardware & Hardware Repair | 5 | 07-18-2008 21:45 |
6680 after water damage can't on | zijean | Nokia Hardware & Hardware Repair | 0 | 06-10-2008 07:25 |
T610 water damaged -- can't power up but flashes ok | andreic | Sony Ericsson Hardware Repair | 2 | 05-23-2004 13:06 |
6510 after water damage can't turn on | Destructor | Nokia Hardware & Hardware Repair | 3 | 11-18-2003 19:18 |
8210 water damage can't switch on but... | dragories | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-29-2002 18:31 |
