03-07-2003, 02:27 | #1 (permalink) |
Freak Poster Join Date: Jun 2001 Location: Huddersfield, UK
Member: 4850 Status: Offline Thanks Meter: 3 | 3310 de-charges bettery the problem is that when u stick the charger in the fone will say charging and then about a minute later the top half of the fone gets very very hot and the battery discharges i hav tried 4 different batteries same problem!!!! so n e one have a solution?? |
03-07-2003, 02:34 | #2 (permalink) |
No Life Poster Join Date: Oct 2002 Location: PARIS
Member: 16856 Status: Offline Sonork: 1582037 Thanks Meter: 441 | You said it's dropped ! Dropped on the water ? If it is how supposed to be , you need to open and clean all pcb ! But it's not very sure to repair if it's oxidised. But if it's just dropped on the floor, take a look to the battery connector, and system connector if it's there not a short circuit or contacs broken inside ! Max_B P.S. Sorry for my English |
03-07-2003, 02:36 | #3 (permalink) |
Member: 4850 Status: Offline Thanks Meter: 3 | thanx for the quick reply the person hu brought it to me sed it had been dropped on the floor i opened it there was problems with the connecters or broken contacts |
03-12-2003, 08:46 | #6 (permalink) |
Member: 16856 Status: Offline Sonork: 1582037 Thanks Meter: 441 | If it's not a faulty component ! You can check your batteries, if it's not on high impedance . The BMC3 needs to be under 0,36 Ohm for working correctly. But with 4 different batteries it sholud be an electronical problem. Max |
3310 auto charging and then not charging and then reconnect charger | hooi76 | Nokia Hardware & Hardware Repair | 6 | 08-17-2010 12:25 |
nokia 3310 sometime chargs sometime shows not charging,help me | shivam mobile | Nokia Hardware & Hardware Repair | 4 | 02-20-2008 10:47 |
3310 When Charged Auto On And Not Charging | remylebeau | Nokia Hardware & Hardware Repair | 6 | 03-27-2007 13:26 |
nokia 3310 shows charging but not charging | crossings | Nokia Hardware & Hardware Repair | 5 | 11-07-2003 13:23 |
3310 show charging but not charge!!! | florinmar | Nokia Hardware & Hardware Repair | 3 | 05-28-2003 09:25 |
