04-03-2003, 17:16 | #1 (permalink) |
No Life Poster Join Date: Aug 2002 Location: india Age: 63
Member: 14578 Status: Offline Thanks Meter: 831 | 3310 power on problem 3310 water damage. after cleaning and rebow phone, flash read and write ok. not power on. conect with bsi to ground 22k res, power on ok. what should be fault ? thanks in advance. |
04-03-2003, 17:58 | #2 (permalink) |
No Life Poster Join Date: Feb 2003 Location: India Age: 39
Member: 20691 Status: Offline Thanks Meter: 20 | @baraka42 Hello Friend..... i have got the same problem in 3310 phone is dead and water damaged, i cleaned the phone .....but no result... the phone accepts flashing but not getting power ON. You wrote this sentence (conect with bsi to ground 22k res, power on ok.) Can you please explain me in details what is that bsi and where is the 22k res. ? Thanx in Advance, reply soon Regards, Tanvir !!! |
04-04-2003, 19:03 | #3 (permalink) |
Freak Poster Join Date: Sep 2002 Location: Nokialand Age: 42
Member: 15909 Status: Offline Thanks Meter: 0 | Cleaning with alcohol, or with ultrasonic cleaner and specified antioxid fluid? Use only ultrasonic cleaner!!! And if not work after cleaning, check 26Mhz crystal oscillator, and Hagar clock out (13Mhz - external system clock). If all ok, i think CCONT Fault. |
04-06-2003, 12:14 | #5 (permalink) |
Member: 14578 Status: Offline Thanks Meter: 831 | @ Springer thanks, i hav't ultrasonic cleaner.eccept this i had try every cleaning method. @ Tanvir and monti. pls. contact me on mail.i you use ultrasonic cleaner and b.g.a. solder balls? it is available in india. ? thx. all. |
04-07-2003, 22:17 | #7 (permalink) |
No Life Poster Join Date: Sep 2001 Location: Bosnia and Herzegovina Age: 50
Member: 6464 Status: Offline Thanks Meter: 6 | Hi! I had many 3310 water damaged...every time my first step is to clean and resolder all BGA ICs (without CPU,of course)! If not power on,only then you can start to think about changing any IC! Regards SHiljo |
04-08-2003, 12:58 | #8 (permalink) |
Member: 14578 Status: Offline Thanks Meter: 831 | @ monti, chack your mail. @ shiljo without reballing and changing any bga, i do every thing with schematic. no result. thx. for your time to reply me. |
7610 power on problem no power on with power touch | shani72 | Nokia Hardware & Hardware Repair | 2 | 09-10-2008 05:51 |
3310 Power On Problem | jamohaki | Nokia Hardware & Hardware Repair | 2 | 01-25-2006 08:56 |
3310 Power On Problem | Destructor | Nokia Hardware & Hardware Repair | 5 | 09-30-2004 16:44 |
3310 power on problem | Pajo | Nokia Hardware & Hardware Repair | 6 | 11-24-2003 01:06 |
3310 power-on problem... | nightxyz | Nokia Hardware & Hardware Repair | 1 | 06-08-2002 12:51 |
