Old 05-02-2009, 16:59   #1 (permalink)
sahed07860's Avatar
Member: 648453
Thanks Meter: 82
6600 only nokia
pls help nokia6600 on only nokia.i try to hand formating useing pw+*yes+*+3 but set not format mode.i also flash set After flash processing...
Waiting for phone to boot...
Reading...
Failed! Aborting!...MCUVER
pls help
The Following User Says Thank You to sahed07860 For This Useful Post:
Old 05-02-2009, 17:03   #2 (permalink)
erick_ponsel88's Avatar
Member: 969971
Sonork: Vincent_Lim
Thanks Meter: 294
Reading...
pls help
Change flash ic (D316) see at schematics
solve your problem...
BR....
Old 05-02-2009, 17:07   #3 (permalink)
[ABDULLAH]'s Avatar
Member: 1021182
Thanks Meter: 39
Try it on difrent box and flash ver then post results
Old 05-02-2009, 17:08   #4 (permalink)
shahidsattar's Avatar
Member: 388454
Thanks Meter: 1,101
remove small crystal ic. behind bettry connecter
Old 05-02-2009, 17:54   #5 (permalink)
gsmshare's Avatar
Member: 429569
Thanks Meter: 1,543
Reading...
pls help
brother try 1st like that :::::
1/ erase(3time)
2/flash
3/writte pm
4/ui setting
5/formatte
if still same give this jumper...................................
save :http://www.usaupload.net/d/h2w4d9o81gd
hope solved ur problem,,,,try and post result
regards
gsmshare
The Following User Says Thank You to gsmshare For This Useful Post:
Old 05-02-2009, 20:56   #6 (permalink)
vishal123123's Avatar
Member: 463150
Thanks Meter: 91
its seems like booting i.c problem. try to change boot i.c before changing flash
Old 05-02-2009, 21:38   #7 (permalink)
roy_naber's Avatar
Member: 395897
Thanks Meter: 56
hi.. i think its the boot ic bro.
try this:
Old 05-05-2009, 14:47   #8 (permalink)
mkhan's Avatar
Member: 178659
Thanks Meter: 46
thnx bro slution is 10000000000000000000000000000000000000000000000000 00000% warking.
Old 05-05-2009, 16:05   #9 (permalink)
panipat's Avatar
Member: 995130
Sonork: SAMRAT
Thanks Meter: 34
BR....
bhai change thiis boot ic then cpu rebool ok
The Following User Says Thank You to panipat For This Useful Post:
6600 only nokia help me shivam4you Nokia Hardware & Hardware Repair 7 08-06-2009 13:55
nokia 6600 only shows nokia with battery not software {like HWK} asif_ae Nokia Hardware & Hardware Repair 3 10-18-2008 16:57
6600 only nokia shaheb_anl Nokia Hardware & Hardware Repair 15 04-23-2008 11:36
6600 only nokia zone2 UFS - Pro 3 11-24-2007 13:15
Page generated in 0.19457 seconds with 10 queries
