04-22-2007, 06:54 | #1 (permalink) |
No Life Poster Join Date: Apr 2005 Age: 45
Member: 139388 Status: Offline Thanks Meter: 98 | 6600 i never faced this problem before When i return the handset to the customer.I was seen So much of applications was installed in the phone.if we opened any application it was slow to open or sometimes it will become white light and restart. So said to the customer.Don't install so many application in the phone and first remove it. While removing the 3rd application from the phone.The phone was shutdowned immediately.After that phone does'nt trun on ???? Then i tried to flash the phone in jaf,Ufs and universal box But always error Here the jaf logs MCU Flash file: D:\Program Files\Nokia\Phoenix\Products\NHL-10\NHL105530.C1 PPM Flash file: D:\Program Files\Nokia\Phoenix\Products\NHL-10\NHL105530.34 CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Languages in ppm: English,Philipinnes (APAC2/Philippines) MCU: D:\Program Files\Nokia\Phoenix\Products\NHL-10\NHL105530.C1 Booting phone... MCU ID: 0x1081 BOOT file: D:\Program Files\ODEON\JAF\Flash\w3_2nd.fia Loader version: 04.3D.00 -> Revision: 0007 Boot size is 0x1090 Boot is ready... FLASH ID0: 7C7E7C7E -> Unknown flash chip Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 0 FLASH ID1: 7C7E7C7E -> Unknown flash chip Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 FLASH ID2: 7C7E7C7E -> Unknown flash chip Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 0 FLASH ID3: 7C7E7C7E -> Unknown flash chip Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0 First 16 bytes: 7C 7E 7C 7E 7C 7E 7C 7E 7C 7E 7C 7E 7C 7E 7C 7E Flash ID is 0x7E7C7E7C Cannot find flash loader for this phone...Aborting! Error Loading loader! I never faced this problem before and i not even heared like this problem Needed solution |
04-22-2007, 08:16 | #3 (permalink) |
No Life Poster Join Date: Aug 2005 Location: SILIGURI Age: 46
Member: 170589 Status: Offline Thanks Meter: 1,848 | I faced approximate same problem and i took time from customer and therefore the operation starts, i opened the set and clean the board nicely and dried it than i kept that board over the computer monitor (not the tft monitor) kept it for an about 12 hours that board was fully heat, i normalised the temperature and re assemble the set and tried to on, miracle it on with white light, i flashed with jaf it ok. i faced it due to switch change. |
04-22-2007, 08:18 | #4 (permalink) |
Member: 170589 Status: Offline Thanks Meter: 1,848 | look nicely on the board while changing the keypad ic flash ic is nearer to it it may happen that a abnormal heat transfered to that flash ic while changing keypad ic once i found contact provider i formatted it it was ok. |
04-22-2007, 12:06 | #8 (permalink) |
No Life Poster Join Date: May 2006 Location: in the corner Age: 35
Member: 285779 Status: Offline Thanks Meter: 49 | Last edited by amei8141; 05-25-2007 at 11:49. |
6681 bluetooth as never faced this prob b4 | pdapower | Nokia Hardware & Hardware Repair | 7 | 05-21-2009 00:56 |
6600 i never faced this problem before | celluniversal | Universalbox | 2 | 04-22-2007 13:42 |
7110 have never seen this problem before | hulala.[uk] | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 03-29-2003 16:35 |
