08-06-2006, 05:25 | #1 (permalink) |
Insane Poster Join Date: Sep 2005 Age: 45
Member: 177298 Status: Offline Thanks Meter: 2 | 3650/60 New 4Blinks Solution I recently just tried this solution for Nokia 3650/60 4 Blinks problem. I am using twister dongle. And just maybe, the supply is not enough for the phone to go in local mode when the status is 4 blinks w/o flashing it. But when i revised the cable and used a 9v batt, the local mode displayed even i didn't flash the phone. I just did it like this: 1. Connect the cable to the 9v batt. 2. Connect it to the phone 3. Connect it to the dongle. (at this point the "NOKIA" must be on the screen w/o the blinks, if not, just slightly press the power on button to let the "NOKIA" display.) 4. Format User Area, UI Default,..etc 5. Init Sim Locks Just like that! I tried and tested it to 3650/60 whose problem is just SW! I tried it maybe,.. more than 25 phones. Maybe it's not a 100% ok but, It'll be a lot of help!! Pls post some response and reaction from experts in here! *** SPEED!! |
08-06-2006, 07:52 | #3 (permalink) | |
Junior Member Join Date: Jul 2006 Location: Caloocan Phils. Age: 46
Member: 322319 Status: Offline Thanks Meter: 4 | just flash it with the same version... Quote:
twister or jaf box, its ok with the 4 blinks problem.... No need to worry... Baby Rain | |
08-25-2006, 16:38 | #11 (permalink) |
Freak Poster Join Date: Jun 2006 Location: pok wong malaysia
Member: 300886 Status: Offline Thanks Meter: 61 | This problem sometime of course came from dropping amphere and voltage. it is usually when we use laptop, old computer with usb 1.1 and computer with low power(watt) power supply. |
09-01-2006, 17:30 | #13 (permalink) |
No Life Poster Join Date: Jan 2002 Location: freak land Age: 44
Member: 8866 Status: Offline Thanks Meter: 50 | the problem was solved by griffin because with i twister couldn`t put the phone in local mode .... after local mode u can format user area, unlock etc |
09-02-2006, 06:25 | #14 (permalink) |
Insane Poster Join Date: Jul 2004 Location: Inside My Pc
Member: 72392 Status: Offline Thanks Meter: 3 | perhaps you can modify those old twister cables by connecting/inserting a 3.3k or 10k resistor between the BSI and the negative....so s to put the unit in test/local mode to do format user area... |
Solution Contact Retailer 6600-3650-60/3230/7610 & 6260. | king.of.gsm | Nokia Hardware & Hardware Repair | 0 | 12-12-2009 20:05 |
3650 net work 10000000% solution | biniesh_08 | Nokia Hardware & Hardware Repair | 0 | 04-16-2009 17:03 |
3650/60 New 4Blinks Solution | vinay_sharma | Nokia Hardware & Hardware Repair | 4 | 12-13-2007 14:02 |
6610,7250,3100,6600,3650/60 flash chip numbers | cgsm | Nokia Hardware & Hardware Repair | 21 | 05-04-2007 12:00 |
Nokia 3650/60 pinnout schematics | TetraUK | UFS2 + UFS3-Tornadoflasher | 1 | 10-20-2004 17:51 |
