07-14-2007, 04:15 | #1 (permalink) |
Junior Member Join Date: Jun 2007
Member: 524178 Status: Offline Thanks Meter: 0 | 6600 keypad problems I have a nokia 6600. My problem is the #2 button and endcall button won't work. I open the front casing then press the pads and it works but i need to push it hard. Can any1 help me with this. thanks. |
07-14-2007, 04:50 | #3 (permalink) | |
No Life Poster Join Date: Feb 2007 Location: K.S.A
Member: 444785 Status: Offline Thanks Meter: 170 | Quote:
The Following User Says Thank You to zahed1978 For This Useful Post: |
07-14-2007, 07:57 | #4 (permalink) | |
No Life Poster Join Date: Jan 2006 Location: EGYPT Age: 47
Member: 217479 Status: Offline Thanks Meter: 267 | Yes, it seems just cleaning matter. Quote:
Take off the white sticker that had the press buttons from the flex cable then clean all of them & the pads on the flex cable too, all gonna be OK, good luck ... Last edited by mobilagy; 07-14-2007 at 08:07. | |
07-15-2007, 13:09 | #5 (permalink) |
Member: 524178 Status: Offline Thanks Meter: 0 | Do I just have take the white sticker out? Honestly i'm not a technician and I don't do repair jobs. I also don't have the tools not even the lil screw drivers. How do I take off the flex cable? It seems that the flex cable is connected into something inside the phone. Please understand my ignorance. Thanks. |
07-15-2007, 14:01 | #6 (permalink) |
Member: 217479 Status: Offline Thanks Meter: 267 | No man, just take off the white sticker not the whole flex cable, no need at all to unscrew or disassemble the set !!! Just get the sticker warm some with such hair dryer then pull it out, do the cleaning job then stick it again in proper position, good luck ... |
07-16-2007, 04:14 | #9 (permalink) | |
Major Poster Join Date: Sep 2006 Location: CDO, Philippines Age: 33
Member: 342199 Status: Offline Thanks Meter: 5 | Quote:
try to scratch it with the butt of your twizzer slowly and carefull, also you can clean it using cotton buds with lacquer thinner try it bro... hope can help.... post the result | |
09-23-2007, 08:47 | #13 (permalink) | |
Member: 217479 Status: Offline Thanks Meter: 267 | Quote:
Thnx, but you have missed the flash chip numbers in this picture !!! You may check this for right one >>> | |
Nokia 6600 keypad problem | vali.rusu | Nokia Hardware & Hardware Repair | 5 | 08-30-2010 23:34 |
6600 keypad problem strange | kprajeesh4u | Nokia Hardware & Hardware Repair | 10 | 09-23-2007 08:00 |
6600 keypad problem | rvnl_adrian | WD2 & APE (Symbian Phones) | 0 | 01-08-2007 08:55 |
6600 Keypad problem | Cloud-Strife | Nokia Hardware & Hardware Repair | 2 | 12-16-2005 05:23 |
6600 keypad problem | Keke | Nokia Hardware & Hardware Repair | 21 | 01-25-2005 20:49 |
