09-22-2008, 04:41 | #1 (permalink) |
Insane Poster Join Date: Jan 2008
Member: 691165 Status: Offline Thanks Meter: 10 | 6670 problem... can post solution?? regards every1... thx... |
09-22-2008, 04:51 | #2 (permalink) | |
Freak Poster Join Date: Jun 2008 Location: pahang Age: 37
Member: 792839 Status: Offline Thanks Meter: 1,104 | Quote:
ram ic ... post resault | |
09-22-2008, 04:54 | #3 (permalink) |
Freak Poster Join Date: Sep 2006 Age: 41
Member: 343227 Status: Offline Thanks Meter: 22 | sir first try to use the search button. there threads regarding this kind of problem. any ways. flash the unit for you to see if all the flash chips can be red? if not?! phones fault is the ram chip. try to re flow or re solder it. if it does not work? try lifting it and clean the balls under it ang put it back again or replace it. hope it helps. |
The Following User Says Thank You to techseeker"ems" For This Useful Post: |
nokia 6670 problem | smart user | Nokia Hardware & Hardware Repair | 2 | 08-10-2006 08:07 |
6670 problem, need help | shakeelajmal | Nokia Hardware & Hardware Repair | 14 | 02-19-2006 22:00 |
6670 problem | Peldiller | Nokia Hardware & Hardware Repair | 4 | 01-22-2006 20:24 |
flashing 6670.. PROBLEMS | UnlockBR | Griffin | 9 | 09-02-2005 17:51 |
