06-03-2004, 06:10 | #3 (permalink) |
Insane Poster Join Date: Apr 2004
Member: 61249 Status: Offline Thanks Meter: 0 | 7250 lcd MAN DONT WORRY it is very easy.(Refer the attachement) In the figure u can see two squared connection points.Fix the display connector with glue on the connector place ,then check the connectivity of these connection pins to.Then connect these points through small thin coils. Regards enjoy |
06-03-2004, 19:54 | #5 (permalink) |
No Life Poster Join Date: Sep 2003 Age: 66
Member: 39601 Status: Offline Thanks Meter: 13 | @Gsm_style..... If U mean islands = the PCB pads , all are ripped ?!! OK no problem. Here is an image with the connection to the test points all U need is to fix the socket on the PCB with an epoxi ,then connect it as in the photo. GoodLuck |
06-05-2004, 06:05 | #7 (permalink) |
Member: 61249 Status: Offline Thanks Meter: 0 | Hi Medz, U described it very clearly.This picture is very much useful for every body.GSM Style may be happy now.medz u have done agreat job, u described what actully i meant. Thanx |
06-05-2004, 23:38 | #8 (permalink) |
Freak Poster Join Date: Mar 2003 Location: nederland Age: 52
Member: 24929 Status: Offline Thanks Meter: 7 | medz can you tell me how i must do this, i try but the speace between the contacts is so small, (connector) they touch each other, i try to make a britch with a very thin insulated wire |
6610 and 7250 with problem NO LIGHT IN THE DISPLAY | flechazo | Nokia Hardware & Hardware Repair | 25 | 09-07-2009 07:38 |
5800 Display Problem (With Display On FBUS Cable But No Display using Regular Battery | eyestrain | Nokia Base Band 5 ( BB-5 ) | 1 | 06-21-2009 20:11 |
7250 display contacts | leosedf | Nokia Hardware & Hardware Repair | 7 | 04-29-2004 13:26 |
7250 signal problem | fiZ | Nokia Hardware & Hardware Repair | 5 | 12-09-2003 19:30 |
7250 flashung problems | BCNUNLOCK | Federal One | 7 | 10-26-2003 02:21 |
