Old 08-08-2006, 07:54   #1 (permalink)
Member: 217958
Thanks Meter: 37
7610 "feature not supported"
i have resoldered the camera socket.
flashed 7610 with latest version.
changed the camera ic.
checked camera on another pcb .
does any one of you have solution for this problem
Old 08-13-2006, 19:21   #2 (permalink)
fastlink Jogja's Avatar
Member: 192822
Thanks Meter: 18
change board lcd your problem will solved.. many times i found that problem and change board lcd full will work.
Old 08-14-2006, 07:41   #3 (permalink)
swapnilbombay's Avatar
Member: 268495
Thanks Meter: 27
dont misguide if u dont know than keep quite okie.......
Old 10-10-2006, 05:44   #4 (permalink)
Member: 45635
Thanks Meter: 20
change board lcd your problem will solved.. many times i found that problem and change board lcd full will work...........hehe thanks at alllllll
Old 10-11-2006, 04:44   #5 (permalink)
scion's Avatar
Member: 254324
Thanks Meter: 15
Replace Uem....if U Need New Imei Just Pm Me
Old 10-15-2006, 09:08   #6 (permalink)
Member: 192822
Thanks Meter: 18
i didn't missguide somebody ! you ask other good technician and you will find that change board lcd is only solution.. and i haved tried 2 cases and both solved!!
aku baru tahu kalau orang india sudah dungu banyak omong lagi
do you want me to translate this word for you..?
you know nothing..! KEEP QUIET..!
Old 01-17-2007, 11:15   #7 (permalink)
ashrafcell's Avatar
Member: 232622
Thanks Meter: 17
Thanks you very much
Old 01-17-2007, 14:08   #8 (permalink)
Member: 155401
Thanks Meter: 3
hi
good salouchan problem will solved.
Old 06-17-2007, 14:29   #9 (permalink)
waleed2's Avatar
Member: 85387
Thanks Meter: 78
whats board lcd do you have photo
Old 09-24-2008, 13:44   #10 (permalink)
Member: 775993
Sonork: mani
Thanks Meter: 4
merepek
diam kau .....jangan cakap banyak2......
Old 09-24-2008, 15:20   #11 (permalink)
AdickAsia's Avatar
Member: 801083
Thanks Meter: 99
who are you?
what do you mean sir?
ini maksudnya apa bos?
Old 02-17-2009, 07:05   #12 (permalink)
cellchoice2004's Avatar
Member: 699434
Thanks Meter: 47
wat u mean by that board lcd is it the socket of the lcd or to replace the lcd
Old 02-24-2009, 09:48   #13 (permalink)
Member: 210855
i try but no ok any solution
3230 Camera "Feature Not Supported" metronetGSM Nokia Hardware & Hardware Repair 21 01-06-2011 10:49
6630 Camera "Feature Not Supported" nomi Nokia Hardware & Hardware Repair 4 08-14-2010 08:47
"feature not supported" green bird Nokia Hardware & Hardware Repair 29 01-17-2007 11:40
nokia 7610 "feature not supported" bebiloku Nokia Hardware & Hardware Repair 0 09-14-2006 17:29
6630 and video: "feature not supported"!! area51roby Nokia Base Band 5 ( BB-5 ) 4 08-29-2006 20:03
Page generated in 0.18588 seconds with 9 queries
