Old 09-14-2012, 14:24   #1 (permalink)
Member: 1127257
Thanks Meter: 5
c2-03 3 sec. light flash then blank screen
nokia c2-03 only 3 sec. white light on screen the screen blank but key pad light ok
i already flashed but still same problem.
Old 09-14-2012, 14:27   #2 (permalink)
Cheater -Don't Deal with him-
Member: 1619775
Sonork: 100.1603044
Thanks Meter: 302
This is power ic problem re hot it
Old 09-14-2012, 14:30   #3 (permalink)
Member: 649043
Thanks Meter: 18
Arrow
brother change lcd testing by me or wash lcd connector.
Old 09-14-2012, 14:42   #4 (permalink)
Member: 1707492
Thanks Meter: 606
change flaxe cabel 100% u r pove im tested 5 phone
Old 09-14-2012, 16:24   #5 (permalink)
Member: 1127257
Thanks Meter: 5
this is not frm flex cable .... in new flex ..same problem
Old 09-14-2012, 23:16   #6 (permalink)
Member: 1784997
try flash.................
Old 09-15-2012, 07:19   #7 (permalink)
VIJAY2U2's Avatar
Member: 1039903
Thanks Meter: 2,040
i have same problem
soft,flex,lcd,light component changed done but same
but some times fone work normally but again light problem come
Old 10-06-2012, 11:00   #8 (permalink)
Member: 986980
Thanks Meter: 2
change lcd ur problem iz solved 1000000%
Old 12-15-2012, 09:30   #9 (permalink)
Member: 1340026
Sonork: 123456
Thanks Meter: 13
i have a same problm i change flex,lcd but not solve please help me
C2-03 Nokia white display when powering on then turn to blank after 3 seconds but can make and receive calls.
Old 12-15-2012, 15:24   #10 (permalink)
ASSANDHCDMA's Avatar
Member: 1169871
Thanks Meter: 175
Here Is Solution
Old 01-05-2013, 11:54   #11 (permalink)
Member: 1359325
Sonork: 470928
Thanks Meter: 9
my solution 1000000000000% tested nokia c2-03 all wrong solution my solution is testd only four steep problum 100%
Old 01-05-2013, 11:57   #12 (permalink)
Member: 1359325
Sonork: 470928
Thanks Meter: 9
nokia c2 3secend lcd light solution only four cheng orignal steep
Old 01-10-2013, 14:08   #13 (permalink)
Member: 1169871
Thanks Meter: 175
if u not solve after change stript try it 100% work tested in 20peace
Old 01-10-2013, 15:00   #14 (permalink)
clicathinek
Guest
Posts: n/a
Member:
Old 01-21-2013, 19:28   #15 (permalink)
Member: 1069615
change the display i have tested in 2 handset
Page generated in 0.16918 seconds with 8 queries
