Old 07-14-2013, 14:05   #16 (permalink)
Member: 1035525
Sonork: m-one
have same case, if change lcd, flexible, no result. before doing ic power first of all check if line from conn to r is broken, check Vled, vbat. if all are ok, and there is no Vaux 2.8 v, the solutioin from Assand is finally tested working by me. thanks Assand,
The Following User Says Thank You to MONECELL For This Useful Post:
Old 09-08-2013, 06:32   #17 (permalink)
Member: 1031048
Sonork: 1001615654
Thanks Meter: 2
nokia c2-03
i have change display but problem is same
Old 09-09-2013, 16:51   #18 (permalink)
Member: 975998
Sonork: shahi
Thanks Meter: 2
Changed the lcd ur problem wl solved
Old 09-09-2013, 17:14   #19 (permalink)
hites's Avatar
Member: 1877713
Sonork: 100.1640944
Thanks Meter: 21
do software once if not ok then change the flex and display...
Old 01-26-2014, 08:50   #20 (permalink)
Member: 1697277
sir i changed flex cable display then flashed the phone all the same what should i try any solutions
Old 06-23-2014, 12:55   #21 (permalink)
Sukh007's Avatar
Member: 1481018
Sonork: 100.165460
Thanks Meter: 222
i chane flex and version no solution then i conect to box for flashing phone proper working in normal test mode
Old 06-24-2014, 14:35   #22 (permalink)
Cheater -Don't Deal with him-
Member: 880407
Thanks Meter: 63
c2-03 only vibrate when power on
Old 11-28-2014, 05:04   #23 (permalink)
Member: 1711703
Sonork: 124
Originally Posted by bunty_anjum View Post
nokia c2-03 only 3 sec. white light on screen the screen blank but key pad light ok
i already flashed but still same problem.
dear all every know on market many brand lcd so please change lcd your problem 100% s
Old 11-28-2014, 05:25   #24 (permalink)
Member: 1711703
Sonork: 124
i think u done all
1. Check incoming call
1. full flash with latest version
2. Chang flax, LCD
3. Check light way
may help this trick
Old 06-07-2016, 04:05   #25 (permalink)
Member: 2104452
I rehot power ic my problem solved...Lcd light problem solved.
Many Many Thanks
Old 09-30-2016, 08:08   #26 (permalink)
Member: 1748687
Sonork: 100.1656932
Thanks Meter: 26
Many Many Thanks
yes rehot power ic my problem solved also
Old 10-08-2016, 13:10   #27 (permalink)
gul551's Avatar
Member: 565096
Thanks Meter: 1,540
Change lcd i try many sets 10000%% lcd problem
Page generated in 0.16996 seconds with 8 queries
