07-18-2005, 17:23 | #1 (permalink) |
Freak Poster Join Date: Apr 2005
Member: 139043 Status: Offline Thanks Meter: 27 | Does anyone knows how to troubleshoot a phone at all? PLease share post here For example i always had phones with no power and the first thing i check is whether it is water damage if not then i will flash the phone but after that if flashing is not sucessful what do i need to do next,change the pa. But how can we check that the pa is faulty? |
07-19-2005, 12:30 | #2 (permalink) |
Insane Poster Join Date: Dec 2004 Location: Adelaide Australia Age: 39
Member: 96184 Status: Offline Thanks Meter: 6 | do you have nokia service equipment? nokia flash prommar, gsm test head, open jigs, flash jigs, nokia programs? this gear really helps. if not then your restricted majorly. any way simple methods check for liquid ingress, is the battery any good? check for physical dammage, solder bridges. force flash software, clean phone with isopropal alcohol, or other cleaners. you can reflow if the phone looks as new. if none of this works then advanced methods; check if phone draws power. does it turn on when you put it on 12 volts? local mode?, check for physical dammage. try and force flash in 12 volt power supply, reflow upp, flash ic (depending on the model), resolder battery contacts, power switch, check capacitors from battery terminal. if these dont work then your phone must be really dead. you can then replace upp, power amp etc. theres a few things to check. |
07-19-2005, 16:54 | #3 (permalink) |
Member: 139043 Status: Offline Thanks Meter: 27 | [QUOTE=pintphones]do you have nokia service equipment? nokia flash prommar, gsm test head, open jigs, flash jigs, nokia programs? this gear really helps. if not then your restricted majorly. any way simple methods check for liquid ingress, is the battery any good? check for physical dammage, solder bridges. force flash software, clean phone with isopropal alcohol, or other cleaners. you can reflow if the phone looks as new. if none of this works then advanced methods; check if phone draws power. does it turn on when you put it on 12 volts? local mode?, check for physical dammage. try and force flash in 12 volt How can i buy nokia service equipment? what do u mean by 12 volt? and what is solder bridges |
does anyone know how to change the os of nokia clones to symbian? | Benzhai731 | Chinese Models & Cloned Phones | 5 | 07-26-2008 12:09 |
does anyone know how to change the os of nokia clones to symbian? | Benzhai731 | Chinese Models & Cloned Phones | 1 | 07-24-2008 10:06 |
does anyone know where to get t100 cable in midlands please | trippy_zippy | Trident/AGERE Platform | 1 | 06-26-2004 16:44 |
Does anyone know how to re-lock Samsung A300's and how to change the start up logo ? | STB Trading | VLSI, Conexant, Skyworks and Old Models | 9 | 06-18-2002 21:52 |
Does anyone know how to unlock the user-code for all siemens phones? | xpmobile | x1x to x45/x50 | 1 | 01-08-2002 07:49 |
