Old 09-14-2008, 08:50   #31 (permalink)
digitized's Avatar
Member: 163833
Sonork: 100.1579554
Thanks Meter: 5,700
check shoting in nokia 6131,6133,6126......
imp*****to check shoting in this model first remove flex slider from main pcb if ur shoting is gone then there is shoting is in ur uper display portion because there are some ic in upper portion which got +b from batery. through flex..*****
1..remove this coil mark in (1)...if u want to check is pf is short,.....
2..remove this coil mark in (2)..if u want to check rf ic is short because rf ic also got +b volt from battery....
3..remove the resistance mark in (3) ..if u want to check irda module ... because irda module got +b from batery....
4..remove this coil mark in (4)..if u want to check the light ic is short....because light ic got +b from batery....
5..remove this coil mark in (5) if u want to check memory card driver ic n3200 it also got +b from batery.......
6..remove this coil mark in (6)..if u want to check blutooth ic is short because bluetooth ic also got +b volt from battery....
7..remove this ic n3300 mark in (7)..if u want to check the v.cam maker ic ..this v.cam maker ic got +b from batery....this ic make volt for camera .....
8...remove this ic n1200 mark in (8).....this ic also got +b from batery....
9....at end remove retu and tahvo ic to check shoting is gone or not....
all the component which are mark in pink colur these all are coils and resistance these are place in series and +b of batery is gone throw them so if u remove the coil and resistance u not have to remove ic to check the shorting in pcb it save time and ur ic ....
digitized
The Following 45 Users Say Thank You to digitized For This Useful Post:
Old 09-27-2008, 16:17   #32 (permalink)
Member: 439620
Thanks Meter: 23
SIR I HAVE PROBLEM WITH 6630 WHEN I CONNECT IN HWK AND CHECK THERE IS ERROR IS THIS
1ST BOOT : C0,0C [Rm-1] [2.0.8.0]
OMAP ID : 17100701
OMAP MODE : 00
OMAP PBID : FBAB039B06BD6ABEA83C4FA64C14B37FB47770CF
OMAP HASH : 2C05369F57CC3C4CF9E783E83D9B512B
OMAP ROID : AB5E4ADB27A06946
RAPx ID : 000000010000022600010006000C192101002100
EM 1 ID : 00000232
EM 2 ID : 00000352
RAPx PBID : 148002087BD346518DD04BEF9D046CBCE001FDAB
RAPx MODE : 00
RAPx HASH : E9EFF4BFAA5393217CA6B17755FC3E14
RAPx ROID : F28A211FAC901AEE
CMT 1ST Boot OK
CMT 2ND Bt: RAP3Gv2_2nd.fg, Ver: 1.21.0
CMT FLID0 : 00EC2250-00000121, Sam K8S6415ETB
CMT FLCNT : 000000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
CMT MCID0 : FFFF0000-00000000
CMT 2ND Boot OK
CMT ALGO : RAP3Gv3_algo.fg, Ver: 1.40.0
CMT VPP : Internal
DUAL LINE : True
CMT ALG Boot OK
APE 2ND Bt: helen3_2nd.fg, Ver: 1.35.0
00000090: 00 00 ..
ERR: APE 2ND Boot FLB1_MSG_C2: 00000400000000B172 APE 2ND CONF:
Rebooting Mobile
The Following 12 Users Say Thank You to NARESH_RANGLANI For This Useful Post:
Old 09-29-2008, 08:06   #33 (permalink)
digitized's Avatar
Member: 163833
Sonork: 100.1579554
Thanks Meter: 5,700
Originally Posted by naushad09 View Post
thnx digitized sir 4 gr8 help
really nice post
plz sent me 6270 shorting
check shoting in nokia 6270.....
1....remove this COIL mark in (1) if u want to check the shoting of pf .......remove the coil and ur shoting is gone then there is shoting in ur pf .......
4..remove this coil mark in (4)..if u want to check the shoring cause flash light driver ic n1471 ....because this ic got +b from batery....
5...remove this coil mark in (5)..if u want to check the light ic is short....
6...remove bluetooth ic mark in (6)..if u want to check blutooth ic is short because bluetooth ic also got +b volt from battery....
7...remove this coil mark in (7)... to check the shoting cause by ringer ic......because ringer ic got +b from battery through this coil.......
8..remove ic mark in (8)....it is memory card driver ic....remove this if u want to check the shoring cause by this ic....because this ic got +b from batery......
9..remove this ic mark in (9) ...it is vcam maker ic which make vcam for camera ......remove this ic to check shoting because this ic got +b from batery......
10..at end remove retu and tahvo ic to check shoting is gone or not,,,....
all the component which are mark in pink colur these all are coils and resistance these are place in series and +b of batery is gone throw them so if u remove the coil u not have to remove ic to check the shorting in pcb it save time and ur ic ....
digitized
Old 10-16-2008, 07:26   #34 (permalink)
digitized's Avatar
Member: 163833
Sonork: 100.1579554
Thanks Meter: 5,700
Originally Posted by umesh garg View Post
sir 6085 need very urjent.Thanks in advance
check shoting in nokia 6085,6086...........
3..remove this coil mark in (3)..if u want to check the light ic is short....
4..also check the memory card driver ic n3200 mark in (4) it also got +b it can be check by only removing this ic.....
5..remove this ic mark in (5)..if u want to check blutooth ic is short because bluetooth ic also got +b volt from battery....
6..remove this ic mark in (6)....this is wlan pf this also got +b from batery this ic is not in 6085....
7..remove this ic mark in (7)....this is wlan ic this ic got +b from batery this ic is not in 6085....
8..at end remove retu and tahvo ic ..to check shoting is gone or not....
all the component which are mark in pink colur these all are coils these are place in series and +b of batery is gone throw them so if u remove the coil u not have to remove ic to check the shorting in pcb it save time and ur ic ....
digitized
The Following 38 Users Say Thank You to digitized For This Useful Post:
Old 10-29-2008, 05:14   #35 (permalink)
suneel's Avatar
Member: 384984
Thanks Meter: 456
Smile
Originally Posted by digitized View Post
check shoting in nokia 1110,1110i,1112,1600,2610,2310,2626......
1..remove this resistance mark in (1)..if u want to check the light ic is short....in some sets this resistance is not present ...so if it is not present then u have to remove light ic to check shoting is gone or not......
2..remove resistance r2160 mark in (2)..if u want to check the shoting cause by n2160 (speaker ic).....because this ic also got +b from batery......
3..remove ringer ic mark in (3)..if u want to check shoting remove it and check if shoting is gone replace it because ringer ic also got +b volt from battery....
4..remove the pf ic n7700 mark in (4)...if u want to check this ic is short remove it and check shoting...if it is shot then replace it...
5..at end check the power ic d2200 mark in (4) and reemove it to check shoting is there or not...{be careful it is pasted}......
digitized
[email protected]
brother this is very good solulation but add this pf also in your images
first remove this pf 90 %this pf is short in this model i repairemany pc whith this solulation
File Type: jpg 1110,1110i,1112,1600,2610,2310,2626short.JPG (156.8 KB, 2360 views)
The Following 37 Users Say Thank You to suneel For This Useful Post:
Old 10-29-2008, 06:32   #36 (permalink)
digitized's Avatar
Member: 163833
Sonork: 100.1579554
Thanks Meter: 5,700
thanks for ur suggetion .................................
yes these pf are shot when ur set is in water damage case.....
any way thanks .....
br.
digitized...
The Following 13 Users Say Thank You to digitized For This Useful Post:
Old 11-02-2008, 07:52   #37 (permalink)
FEATURE GSM™'s Avatar
Member: 276151
Sonork: 100.1577032
Thanks Meter: 234
i have problem n 70 1ST BOOT : C0,0C [Rm-84] [2.0.8.0]
OMAP ID : 17100701
OMAP MODE : 00
OMAP PBID : 058CE61DE17DE231BBEFCCFD1231E18BF0F23AC9
RAPx ID : 000000010000022600010006000C192101002200
EM 1 ID : 00000232
EM 2 ID : 00000353
RAPx PBID : 0EA0010DD1765A5192B1F83BEA188EE37257AE16
RAPx MODE : 00
RAPx ROID : F28A211FCEA7B19D
CMT 1ST Boot OK
CMT FLCNT : 00000000000000000000000000000000000000
CMT 2ND Boot OK
CMT ALGO : RAP3Gv3_algo_fps8.fg, Ver: 1.12.5
CMT KSIG0 : 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D
CMT VPP : Internal
DUAL LINE : False
CMT ALG Boot OK
IMAGE : RM84_50717301.C0
CMT NOR Erase Area: 0x00000000-0052B515
CMT NOR Erase Area: 0x006A0000-006BFFFF
CMT NOR Erase Area: 0x006DF000-006EFFFF
CMT NOR Erase Area: 0x00700000-007EFFFF
CMT FLASH ERASE OK, Time: 00:44
CMT FLASH WRITE OK, Time: 00:30
OMAP ID : 17100701
OMAP MODE : 00
EM 1 ID : 00000232
EM 2 ID : 00000353
RAPx MODE : 00
CMT 1ST Boot OK
CMT 2ND Boot OK
CMT VPP : Internal
DUAL LINE : False
CMT ALG Boot OK
00000000: 04 00 00 00 00 B1 72 ......r
ERR: APE 2ND Boot FLB_MSG_C2: APE 2ND CONF No Info
Process Failed, Repowering Mobile what is problem help me
The Following 11 Users Say Thank You to FEATURE GSM™ For This Useful Post:
Old 11-03-2008, 09:55   #38 (permalink)
digitized's Avatar
Member: 163833
Sonork: 100.1579554
Thanks Meter: 5,700
Originally Posted by bong echavez84 View Post
need 7610 shorted diagram urgent
history water damage i remove uem and P.A but the same problem plss
check shorting in nokia 6670,7610.......
2...remove this coil mark in (2)..if u want to check the display light ic is short....
3..remove ic mark in (3)... this is memory card driver ic this also got +b from batery....remove it to check shoting is gone or not.......
4...remove this transistor ic mark in (4)...this is transistor ic for key pad light ....remove this if u want to check the shoting cause by this transistor....because this transistor got +b from batery......
5..remove this transistor ic mark in (5)...this ic make volt for lcd 2.5v (vlcd)....this ic got +b from batery ....remove this if u want to check the shoting cause by this transistor.....
6...remove boot ic mark in (6)..if u want to check shoting cause by boot ic if it is short replace it with new one......
7..remove ringer ic mark in (7) ....if u want to check shorting throug ringer ic is gone or not...
8.....remove this smps ic mark in (8)... to check the shoting cause by this ic.........this ic make v corea volt for upp...
9..at end remove uem to check shoting is gone or not.....
digitized
Old 11-20-2008, 07:34   #39 (permalink)
digitized's Avatar
Member: 163833
Sonork: 100.1579554
Thanks Meter: 5,700
check shoting in nokia 1680-c...
1...remove this coil mark in (1)..if u want to check the light ic is short....
2..remove this v.camdig ic n3301 mark in (2)..if u want to check the v.camdig maker ic ..this v.camdig maker ic got +b from batery....to make v,cam for camera.....
4..remove the pf n7700 mark in (4)...if u want to check is pf is short remove it and check shoting...if it is shot then replace it...
5..at end check the power ic and reemove it to check shoting is there or not..
wbr.
..:Preet:..
The Following 35 Users Say Thank You to digitized For This Useful Post:
Old 11-24-2008, 09:26   #40 (permalink)
digitized's Avatar
Member: 163833
Sonork: 100.1579554
Thanks Meter: 5,700
check shoting in nokia 6600 slide....
1..remove these both coil mark in (1)..if u want to check rf ic is short because rf ic also got +b volt from battery....
2...remove these both COIL mark in (2) if u want to check the shoting of pf .......remove the coil and ur shoting is gone then there is shoting in ur pf .......this pf is only used in this circuit for tranmiting signal...(in tx section we say)
3...remove this COIL mark in (3) if u want to check the shoting of pf .......remove the coil and ur shoting is gone then there is shoting in ur pf .......this pf is work for both reciving and transmiting of signal..(this work as antena switch and pf as example in nokia 1110..)
4..remove this coil L3301 mark in (4) if u want to check the shoting cause by n3301,n3302,n3303.....these ic make volt for camera ic ...these ic got +b from batery ...so remove this coil to check shoting is gone or not ..
5..remove this light ic mark in (5)..if u want to check the light ic for display is short....
6..remove ic mark in (6)... this is memory card driver ic this also got +b from batery....remove it to check shoting is gone or not.......
7...remove bluetooth module mark in (7)..if u want to check blutooth ic is short because bluetooth ic also got +b volt from battery....
8..remove this ic mark in (8)..if u want to check the shorting cause flash light driver ic ....because this ic got +b from batery....
9...remove this ic mark in (9)..if u want to check the key boad light ic is short....
10...remove this resistance mark in (10)...if u want to check the ic which are place for controlloing and switching usb charging for the phone these ic are (n2006,n2005)...these ic got +b from batery to work...
11...remove this coil mark in (11)...if u want to check n2001 ic ...this ic is for usb controlling......this ic got +b from batery...
12...remove this ic n2002 mark in (12)...if u want to check this ic ....this ic also for usb controlling......remove this ic because this ic got +b from batery....
13...remove this ic n2000 mark in (13)...if u want to check this ic ....this ic is for controlling usb charging......remove this ic because this ic got +b from batery....
14...at end remove avilma and bety ic to check shoting is gone or not,.......
wbr,
..:Preet:..
The Following 36 Users Say Thank You to digitized For This Useful Post:
Old 11-27-2008, 07:50   #41 (permalink)
Member: 702077
Thanks Meter: 85
check shorting in nokia dct4++ 2630.....
1..remove the pf n7700 mark in (1)...if u want to check is pf is short remove it and check shoting...if it is shot then replace it...
2..remove this coil mark in (2)..if u want to check the light ic is short....
4..remove this v.camdig ic n3301 mark in (4)..if u want to check the v.camdig maker ic ..this v.camdig maker ic got +b from batery....to make v,cam for camera.....
5..remove this ic n6000 bluetooth and fm ic mark in (5)..if u want to check the shoting cause by it remove it and check shoting because it got =b from batery....
6..at end check the power ic and reemove it to check shoting is there or not...
Hi man pls i need some information i got a jaf box and works perfect for me on nokia . I want to get another box 4 samsung motorola ...sonnyerricson .. Wats the best box for thos phones thanks in advance
The Following 12 Users Say Thank You to amalou For This Useful Post:
Old 01-12-2009, 04:26   #42 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
nokia 6120c short
remove these 2 parts mark in picture
The Following 35 Users Say Thank You to HUM For This Useful Post:
Old 01-13-2009, 09:28   #43 (permalink)
Registered User
Member: 195513
Thanks Meter: 67
try this solution http://rapidshare.com/files/18269216...tions.rar.html good luck
The Following 11 Users Say Thank You to glenntelecom For This Useful Post:
Old 01-21-2009, 11:25   #44 (permalink)
Member: 943447
Thanks Meter: 51
pls can some one pls help me with the solution for nokia 3110c blank sreen ps
The Following 5 Users Say Thank You to mobileland139 For This Useful Post:
Old 01-24-2009, 06:49   #45 (permalink)
digitized's Avatar
Member: 163833
Sonork: 100.1579554
Thanks Meter: 5,700
check shoting in nokia phones in one exe ....
credit goes to benua3 ...for making this nice software....
here is link....
http://www.ziddu.com/download/289824...wSafi.rar.html
wbr,
..:Preet:..
The Following 54 Users Say Thank You to digitized For This Useful Post:
Page generated in 0.37299 seconds with 10 queries
