08-22-2004, 16:47 | #3 (permalink) |
Freak Poster Join Date: Jul 2002 Location: MAD Age: 50
Member: 13545 Status: Offline Thanks Meter: 2 | U can reball it this way, put "super glue" on the other side of N150 and push it in order to stick with a metal object, put the stencil on the N150, "on dct4 flash ic hols", put paste and continue ....!!! u can do it easy... ___________ MrHazeem |
08-22-2004, 21:57 | #4 (permalink) |
No Life Poster Join Date: Oct 2001 Location: -------- Age: 55
Member: 7062 Status: Offline Thanks Meter: 126 | @mr. hazem i respect your way very much .. but my way is to put some flux (cream ) on the board pin and you revise it by the tip of the solder iron its so far make the level of it same and you can revise it by magnified lamp .. about the ic its very very very sensitve you must handle with most care you have and but it in rubber double face carfully and to check the pin carfully also under magnified lamp and slowly you use fluxed solder wire to fit it after you furnish the ic with flux too the tip of iron ll fit new balles ( small ones ) but almost same .. clean it well use soft prush .. and fit it again on board. use alawys mid heat with esd ic ,s even if it take much time best of luck for you br. |
08-23-2004, 13:45 | #6 (permalink) | |
Member: 7062 Status: Offline Thanks Meter: 126 | Quote:
thank you anyway br., | |
08-23-2004, 13:58 | #7 (permalink) |
No Life Poster Join Date: Apr 2001 Age: 47
Member: 4249 Status: Offline Thanks Meter: 2 | @ raheeeb i appreciate your reply and your help, I just try to show to him that it is available in the markets with low price because may be he don't know... sorry for misunderstanding br |
08-23-2004, 17:23 | #8 (permalink) |
No Life Poster Join Date: Dec 2000 Location: uk
Member: 2899 Status: Offline Thanks Meter: 6 | hi guys and thank u for your tips,but they seem to be very difficult and time consuming!!,i hope theres another easier way!!(i just started replacing components!)ii.e ready balled ic etc,i wish somebody gives a link or something!thanx again for your tips. br farry |
01-04-2005, 05:54 | #11 (permalink) | |
No Life Poster Join Date: May 2001 Location: Bulgaria Age: 56
Member: 4627 Status: Offline Sonork: 57528:debeliamark Thanks Meter: 1,034 | Quote:
Reballing IC Method / Flash IC Reballing (for beginers) **** | khem | Nokia Hardware & Hardware Repair | 17 | 08-16-2010 20:30 |
Z3x Team do you have any idea to release Samsung boot repair tool? | Mr.3. | Z3X-Team Products | 2 | 03-29-2010 10:51 |
need "how to do " as the first step | adam92se | LG | 4 | 05-31-2005 10:27 |
Some explanation "How to use IMEI rebuild/repair function" | Raskal | Griffin | 65 | 09-28-2004 10:21 |
"how du get phonebook info if your phone says insert sim" | farry | Nokia Multimedia | 5 | 09-08-2003 17:16 |
