Old 02-17-2017, 17:05   #1 (permalink)
Member: 1752885
Thanks Meter: 4
Lumia 735 Charging Way
Hi Guys,
have a Lumia 735 which wont charge with USB.
Changed USB Connector already without Success.
The Phone charging with Wireless Charger, but not with USB.
Is there an IC which I can bridge?
The Following User Says Thank You to mimk97 For This Useful Post:
Old 02-17-2017, 18:49   #2 (permalink)
Moderator
.:SARCAR:.'s Avatar
Member: 322206
Sonork: 100.1594813/.:SARCAR:.
Thanks Meter: 1,350
hi ,
first check vchg in voltage at J3300 , it's about dc 5v there . if voltage is ok then remove V3300 (marked in attach picture) & short it's two points A1+A2 (described in attach picture)
connect charger & check if still same problem then remove both Z3300 & Z3302 (marked in picture) . if problem still remain then you need to replace charging regulator V3301 (marked in attach picture) .
post result
The Following 4 Users Say Thank You to .:SARCAR:. For This Useful Post:
Old 02-18-2017, 09:15   #3 (permalink)
Member: 1752885
Thanks Meter: 4
Thanks
Will check it
Old 02-20-2017, 11:11   #4 (permalink)
Member: 1752885
Thanks Meter: 4
V3300 bridge 100% worked.
Thanks a Lot !
Old 02-20-2017, 11:18   #5 (permalink)
Member: 2177078
Sonork: family
Thanks Meter: 2
Originally Posted by .:SARCAR:. View Post
hi ,
post result
very usefull, thanks for sharing bro.
Page generated in 0.12808 seconds with 9 queries
