05-02-2002, 00:05 | #1 (permalink) |
No Life Poster Join Date: Nov 2001 Location: Slovakia
Member: 7586 Status: Offline Thanks Meter: 11 | N3310 power switch damaged .. I have N3310 with damaged power on switch . I can replace it but PCB is also damaged. This power on switch has 4 contacts on board , and 2 (both bottom) are on PCB damaged. Can i fix it by another way ?? Have a nice day. Pali |
05-03-2002, 01:34 | #2 (permalink) |
Major Poster Join Date: Dec 2001 Location: rp
Member: 8113 Status: Offline Thanks Meter: 1 | Hello Pali, I do not know the extent of the damage on the pcb but i would just like to give you a suggestion that you may try (or to give you an idea). You could attach jumper wires (insulated) towards the switch contacts. After that you may use epoxy adhesive to permanently position the switch. But be careful not to apply on the moving part of the switch. Let it cure for a day to be sure that the connection is sturdy. I hope that some how you could visualize what i mean. Good luck. |
6680 water damage . power switch not working. | TRABEL | Nokia Hardware & Hardware Repair | 13 | 06-10-2009 14:12 |
7250 Power Switch Solder Pad Damage | VEX-CELL | Nokia Hardware & Hardware Repair | 0 | 10-22-2008 09:21 |
6600 Power Switch and R132 Damaged | alamgir80 | Nokia Hardware & Hardware Repair | 3 | 07-07-2008 07:48 |
3200 power switch, new switch? | sjakie | Nokia Hardware & Hardware Repair | 5 | 02-14-2006 22:58 |
8310 damaged power switch | GsMen | Nokia Hardware & Hardware Repair | 15 | 03-27-2003 15:50 |
