05-28-2011, 11:28 | #1 (permalink) |
No Life Poster Join Date: Nov 2004 Age: 45
Member: 93284 Status: Offline Thanks Meter: 202 | N95 8GB mass memory corrupted I reflow D5200, D4800 and changed N4200, N5200 and always the same. I did measure voltage at C5203, J5207, C5204 and always is same story: when phone startup then appear 1.8V two times but during memory test with Phoenix there is 0V all the time. At C5202 is OK V=VBat. I also tired with other flex and lcd but it didn't help. Any suggestions BR |
05-28-2011, 19:20 | #2 (permalink) |
Moderator Join Date: Jul 2006 Location: Midnapore,West-Bengal,India
Member: 322206 Status: Offline Sonork: 100.1594813/.:SARCAR:. Thanks Meter: 1,350 | have u flash ur set yet? if not try to flash first before going to hardware. also post here d selftest log , if u face same problem then u need to replace D5200. post result |
The Following 2 Users Say Thank You to .:SARCAR:. For This Useful Post: |
05-29-2011, 10:28 | #3 (permalink) |
Member: 93284 Status: Offline Thanks Meter: 202 | I did flash phone at the begining with several boxes but always the same. I also try to format memory through box (then i got errors) and with 3 + * + send key + power but without success. Tomorow I'll post selftest results BR |
05-29-2011, 10:33 | #4 (permalink) |
Junior Member Join Date: Oct 2007 Location: philippines
Member: 619367 Status: Offline Sonork: 100.1645633 Thanks Meter: 16 | format your phone using usb connection tested by me many times. make sure that your computer have properly instaled the n95 usb driver and will recognized it! |
05-30-2011, 10:29 | #6 (permalink) |
Member: 322206 Status: Offline Sonork: 100.1594813/.:SARCAR:. Thanks Meter: 1,350 | ok , from ur selftest log mass memory if test result has passed so try to reball D5200 first otherwise u need to replace it. post the result please. |
The Following User Says Thank You to .:SARCAR:. For This Useful Post: |
Corrupted eeprom data in 3210 | cole | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 10 | 03-02-2002 04:58 |
Fatal Error: Memory Allocation Error ! | fireballz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 7 | 08-03-2001 08:46 |
Nokia Memory Map | Sampaio | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 07-17-2001 22:22 |
24C16 E2prom Memory. | El viejo Rimsky | Nokia Hardware & Hardware Repair | 0 | 01-09-2000 15:46 |
3110 Memory Map. | WATTMAN | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 07-09-1999 00:50 |
