Old 03-04-2004, 10:41   #1 (permalink)
Member: 56734
3210 screen fault
Hi,
I've got an old Nokia 3210 that has a fault: the screen is blank. It charges OK. Turn it on and the backlight comes on. Keys beep. Just no display. I'ev swapped the screen assembly and elastomer for new ones, hoping I could get a cheap spare phone for my kid.
Do you guys know what might be the likely fault? I suspect a hardware problem on the PCB and a costly repair.
Cheersthenyeah
BigRich
Old 03-05-2004, 14:58   #2 (permalink)
Member: 15149
Thanks Meter: 61
have you check the line go to lcd?
Old 03-05-2004, 18:47   #3 (permalink)
ARS
Member: 2721
Thanks Meter: 23
can be damaged CPU. Look in to a service manual and chceck lines from LCD. One of lines go to resistor near CPU. One time i had problem that this resistor was shorted and it was bad CPU
8910i screen fault? Hotdog Nokia Hardware & Hardware Repair 2 10-07-2004 15:49
GX10i weird main screen fault rotorman Sharp 0 09-11-2004 10:56
V50 Screen Fault yeldar Motorola Old Legacy (EMMI) 1 02-27-2003 12:41
3210 1800Mhz fault Zoolee Nokia Hardware & Hardware Repair 5 02-22-2003 04:35
3210 Charging fault Vicky Nokia Hardware & Hardware Repair 7 12-10-2001 00:49
Page generated in 0.12084 seconds with 9 queries
