09-01-2006, 23:40 | #1 (permalink) |
Freak Poster Join Date: May 2006
Member: 283474 Status: Offline Thanks Meter: 41 | Nokia 3230 virus |
09-02-2006, 13:23 | #5 (permalink) |
Freak Poster Join Date: Aug 2006 Location: Kishtwar/Islamaabad j&k Age: 45
Member: 326228 Status: Offline Thanks Meter: 31 | Here is a tutorial which i found on www.symbianforum.be and was posted by d3vil9 so i do not take any credit. Thanks to org poster, enjoy all. Its important to read through this topic before you proceed with formatting, you will need to charge your phone at least half full to enable a successful format. --- Soft Reset *#7780# : Restores ini files from rom but preserves user data (photos, 3rd party apps etc) - Hard Reset *#7370# : This reformats the C: drive completely and all applications and files stored on this drive will be lost. * --- With *#7370# and *#7780# the lock code will be asked before formatting the phone so be sure to remember your code, the DEFAULT CODE by nokia is 12345. * --- Firstly you might want to make a back up of all your important bookmarks, calender, notes and contacts, Using file manager go to c:/system/data find bookmarks.db for bookmarks, calendar for calendar, notepad.dat for notes, and Contacts.cdb for contacts. * --- Contacts can only be copied when phone is in offline mode/flight mode, use Psiloc System Tools for flight mode, not needed on 6630 or later. Or you can use Contact Manager app * --- Ok so 7650, 3650, 3660, ngage and ngage qd can only be formatted using *#7370# Before your format, be sure that the problem is on phone, remove mmc and see if problem still exists. * --- Also try starting in safe mode (press and hold pencil/abc key while turning on till op logo comes up). You can solve an apparent problem with simple solution --- 6260, 6600, 6620, 6670, 7610, 6630, 6680, n70 etc: Turn phone off, press and hold the green (talk) key on the left + number 3 on the keypad + the * key and then turn the phone back on. Keep pressed until phone boots up. * --- Fonts and Formatting. If you have any fonts installed be sure to remove them using Font Remover app or go to c/ or e/ system/ fonts/ and rename it to whatever and delete it now reboot phone before you attempt format. * --- and above all,this is very important,don't mess with file explorers (delete,rename,alter files) if you don't know what your doing. * --- and yes,formating phone (soft/hard) can screw some app's on mmc. Some will work fine,others don't coz they share files on both drives (c:/e: ) * --- OPERA - to copy opera bookmarks before formatting mmc, assuming opera is installed on e-drive. e/system/data/opera/bookmarks |
09-02-2006, 15:07 | #6 (permalink) |
Freak Poster Join Date: Apr 2006 Location: Inside PM
Member: 258154 Status: Offline Thanks Meter: 319 | Hi Mate Just Search in the Forum...i have already posted the "Anticommwarrior.sis" software just format ur phone and MMC then install the above soft and scan it will remove the virus and ur phone will be ok ..tested by me on 345 pcs..1000000% worked. Regards Adampur Hawks |
09-10-2006, 13:32 | #8 (permalink) | |
No Life Poster Join Date: Mar 2005 Location: lets See.
Member: 128918 Status: Offline Thanks Meter: 282 | Quote:
Best way is use hard reset 7370 But Some time u get a white screen after rebooting tested So here is safeway to ged rid from Com Warrior thing Best Regards Last edited by Afzaal; 09-17-2006 at 07:25. | |
09-10-2007, 10:18 | #13 (permalink) |
Major Poster Join Date: Jul 2007 Location: Pakistan , LAhore Age: 39
Member: 538854 Status: Offline Thanks Meter: 3 | Hello First of of all you Format User Area With UFS OR Jaf OR MT Box, & You can Format YOur Phone Manualy Apply This Command *+3+yes==>call Log Button and Than Power On Your Phone Affter 7 Second Your Will Be See Formating on your Phone your phone will be format and you can apply *#7370# Cod on your phone. SEcond Scan Your MMC In Compuer With Mcafee 9.0 Full Updated Antivirus Commwarior Hasbeen Detected And Deleted Now you can use it easly. Thans Best Regard |
nokia 3230 nokia nokia restart pro so i have the set with jaf but it shows this error | lavkey | Nokia Hardware & Hardware Repair | 1 | 10-06-2008 14:14 |
Service Manual for Nokia 3230 and Nokia 8800 | janar_jk | Nokia Digital Core Technology 4 ( DCT-4 ) | 10 | 01-03-2006 16:07 |
nokia pc suite 6.5 and nokia 3230 | Koponen | Nokia Multimedia | 16 | 09-01-2005 11:06 |
Nokia 3230,Can't Link With Nokia PC Suite 6.5 | ranga | Nokia Multimedia | 1 | 04-15-2005 18:05 |
