Old 02-25-2010, 08:35   #1 (permalink)
akashub's Avatar
Member: 750001
Sonork: 100.1641021
Thanks Meter: 1,269
Wink Nokia Hardware Repairing Technics
NOKIA 6233 DISPLAY WHITE PROBLEM CHECKING METHODE HERE
1)CHECK OR CHANGE DISPLAY
2)RESOLDRING DISPLAY CONNECTOR
3)CHECK VIO 1.8 VOLT
THIS VIO VOLT MISSING?
A)CHECK RED MARKED COIL
B)JUST MAKE THIS JUMBER LIKE THIS PICTURE
4)CHECK FM LCD 2.8 Volt
THIS FM LCD 2.8 Volt MISSING?
A)CHECK THIS RED MARKED COIL
B)CHANGE THIS FM LCD 2.8 VOLT DRIVER OR SHOT THIS 2PRINT LIKE THIS PICTURE
5)CHANGE DISPLAY EMI FILTER(2Nos)
6)LAST CHECK RAP3G REFLOW OR REBALL THIS CHIP
NOKIA LASTEST MODEL 6208c_6202c_RM-458
MMC,DISPLAY,TOUCH SCREEN,KEYPAD AND ON/OFF SOLUTION HERE
REGARDS
AKASHUB
Old 02-25-2010, 08:36   #2 (permalink)
akashub's Avatar
Member: 750001
Sonork: 100.1641021
Thanks Meter: 1,269
1110,1112,1600,2310,2610,6030 SOME TIMES POWER ON,SOME TIMES BLUE DISPLAY,SOME TIMES HANG NOKIA LOGO
THIS HANDSETS SOFTWARE CONNECTING TIME MANY DIFFERENT ERROR SHOW.
ERROR1)
MCU ID: 0x2201
FLASH ID0: 226800EC <=> SAMSUNG (SEC) -> K8S3215ETE Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0
First 16 bytes: 25:06:2008 14:14 -> AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14
Checking RAM for ALGO...
Algo is ready...
BOOTING NOT COMPLETED
ERROR2)
MCU ID: 0x2201
chk Failed! Aborting!
ERROR3)
Cable is not good -> check for 68k resistor b/w bsi-gnd in connector and 3.3k resistor in serial with bsi line
ERROR4)
SOME TIMES SHOW
UPP DAMAGED OR UEM DAMAGE ERROR SHOW!!!!!!!!!!!
AM EXPLAIN HOW TO SOLVED THIS PROBLEM
1)FIRST CHECK EASY CABLE PORT
A)CLEAN OR CHANGE THIS CONNECTOR
B)CHECK PCB CONTECT PICTUER NUMBER-1
2)CHECK BATTERY CONNECTOR
A)RESOLDRING BATTERY CONNECTOR OR CHNAGE IT PICTURE NUMBER-2
3)CHECK BSI LINE
A)CHECK PICTURE NUMBER-3
4)CHECK BSI RESISTER
A)FIRST REMOVE THIS RESISTER THEN CONNECT SOFTWARE
B)SAME ERROR SHOW? CHANGE THIS RESISTER
5)CHECK SECOND LOCAL OSILLATOR 26Mhz CRYSTAL
A)CHNAGE THIS CRYSTAL
30%UEM PROBLEM
20%UPP PROBLEM
My Nokia Hardware Repairing Technics SHIJILFONOTLY Nokia Hardware & Hardware Repair 1547 06-15-2021 06:52
My nokia hardware repairing technics second part SHIJILFONOTLY Nokia Hardware & Hardware Repair 85 08-02-2014 15:52
Nokia Hardware Repairing Technics Vinci_PL Nokia Hardware & Hardware Repair 2 09-20-2009 23:50
My Nokia Hardware Repair Technic udayangacnu Nokia Hardware & Hardware Repair 0 07-06-2009 13:26
Nokia Hardware Repaire In Canada moienshah Nokia Hardware & Hardware Repair 0 08-02-2006 21:12
Page generated in 0.13032 seconds with 9 queries
