02-28-2004, 20:45 | #1 (permalink) |
Freak Poster Join Date: Feb 2004 Age: 56
Member: 52884 Status: Offline Thanks Meter: 13 | power problem |
01-01-2005, 20:20 | #2 (permalink) |
Major Poster Join Date: Sep 2004 Age: 54
Member: 81153 Status: Offline Thanks Meter: 0 | Repair flowchart! Hello friends! This is a VERY good and informative topic if carried forward... Lets add info to this thread! My contribution, Check for 2.8 volts on r224. When u press power switch, it should go to 3.2 volts. If no voltage thenm power ic (ccont) is faulty...now from here onwards, even I am at a loss... Maybe reflow ccont? and check voltage again? also, check continuity between r224 and r 402. Also, it has something to do with v414 and v202 Please keep this thread alive! Reagrds Raja3333 |
01-02-2005, 03:15 | #3 (permalink) |
No Life Poster Join Date: Jun 2003 Age: 37
Member: 30303 Status: Offline Sonork: 1001579198 Thanks Meter: 17 | in 3310 power problem is mostly form ccont and it's work 50% by rehoting it first of like mr raja3333 says chek volteg on on/off switch without pressing butten there are2.8 and after pressing butten there is 3.2 volts on it if not reflow ccont it wll work if not u must change it than u must reflash it if not going on then chek 26mhz crystal if nothing chang 32mhz crystal if nothin remove pa and chek it to power on and u must chek them too r224 and r 402.v414 and v202 and 1 resistant near on off switch in black color ******************Azam************** |
01-02-2005, 06:24 | #4 (permalink) |
Member: 81153 Status: Offline Thanks Meter: 0 | @ azampk Hello friend, Can you guide me how to check the 26 mhz and 32 mhz crystal? I dont have a spectrum analyzer or an oscilloscope. Can it be measured with a digital multimeter ? also, can you guide me....how much will an oscilloscope that can test mobile phones cost? Regards, Raja3333 |
R320sc No Power Problem !! | jojz | Old Ericsson Phones & Sony Phones | 3 | 09-06-2001 18:40 |
8210 power problem | modcell | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-08-2001 14:05 |
POWER PROBLEMS | syd | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 05-02-2001 04:50 |
power problem with g500 | geXaGen | Panasonic | 0 | 03-01-2001 11:05 |
GD70 power problems | marc boncz | Panasonic | 0 | 11-10-2000 14:31 |
