12-02-2006, 13:23 | #1 (permalink) |
Freak Poster Join Date: Oct 2004 Location: South Africa Age: 53
Member: 86981 Status: Offline Thanks Meter: 10 | replacing glass bga ic components heat up the old / broken bga do not pull on it it will work itself loose. tap the side if it when it moves its time to remove. keep the air on it dont put you iron down then try remove it you will rip the pads off. make sure that you have taken note of the way it was put on. once off use good quality flux and a good quality iron, work quick. apply flux to the pads on the boad use quite a bit, go over all the pads make sure that all the pads are there. use a magnifying glass if you have, to. im taking it for granted that you will be usuing a old replacement part, so turn overr the ic that you will be putting on, apply plenty flux use your irion and take off all excess solder so both the board and the bga are de-balled. if you have patience now you wont have to re-ball them. turn the heat down on your iron about 300 works for me aplly plenty flux tho the pads on the board. slighty tin the tip on your iron. and lighly run over the pads. then do the same to th ic. place and re align the ic back on the board / again using flux. (tip the oily yellow flux) dosnt work so well but the water soluble clear flux does. put your hot air station on about 300 with the air tuned to the lowest. anything higher will **** the ic clean off the board. SLOWLY heat up the ic once you see (flux)smoke from the ic and you also notice the ic is sliding into the correct position. increase the air and heat pressure. the air plus the heat will seat the ic properly. DO NOT EVER EVER put you blade or scalpel ontop ofthe ic and place pressure as this will short out the pads below. patience is your frien in this case enjoy kazman __________________ kaz Varkel T1/Lvl 5 Nokia SA |
The Following 2 Users Say Thank You to BalfourCellular For This Useful Post: |
LCD Not Working After Replacing Glass | PurpleKush | iPhone 2 / iPhone 3G / iPhone 3GS | 11 | 02-09-2010 01:34 |
repair damage soldering contact point for the BGA IC video | wingsold | Hardware Repair by brands | 3 | 11-08-2002 08:20 |
can esd really damage bga ic???? | eureka8888 | Hardware Repair by brands | 0 | 05-05-2002 21:48 |
8210 glue under ccont bga ic | digipulse | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 03-02-2002 21:21 |
Cobba BgA ic problem | rhd | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 09-26-2001 13:05 |
