12-16-2005, 15:39 | #32 (permalink) |
No Life Poster Join Date: Mar 2005 Location: Facebook: Java John Age: 43
Member: 122246 Status: Offline Sonork: 100.50000 Thanks Meter: 4,993 | i have write that this solution is only for when phone dosent shut off in 30 sec |
The Following User Says Thank You to Javajohn For This Useful Post: |
12-16-2005, 17:00 | #33 (permalink) |
Freak Poster Join Date: Sep 2001 Location: Estonia Age: 46
Member: 6208 Status: Offline Thanks Meter: 12 | This solution can not be true! 100000% fake! Phone cant register to the network without IMEI. Even if we can flash with patch, then we do not have IMEI and the phone is same bad as "blacklisted". Dont talk absurd please people, who say'n "tested, working". Buy HWK, JAF or DCT4 direct. And thats the solution... |
The Following User Says Thank You to juht For This Useful Post: |
12-17-2005, 11:56 | #34 (permalink) |
Member: 122246 Status: Offline Sonork: 100.50000 Thanks Meter: 4,993 | no man i have that phone working fine 100% i can prove that |
12-17-2005, 12:56 | #35 (permalink) | |
Banned Join Date: Nov 2005
Member: 204243 Status: Offline Thanks Meter: 67 | Quote:
The Following User Says Thank You to N.I.T For This Useful Post: |
12-30-2005, 22:02 | #37 (permalink) |
No Life Poster Join Date: Oct 2005 Location: T.E.T.O.U.A.N
Member: 190492 Status: Offline Sonork: 100.01010100 Thanks Meter: 190 | it-s possible with UFS can i do this opperation with UFS or it-s necessary two box-s UFS and Griffin ...??? i have patch imei files .fia to repair imei Phone ; imei : ????????????? |
The Following User Says Thank You to Tetouan Gsm For This Useful Post: |
12-31-2005, 06:19 | #38 (permalink) | |
No Life Poster Join Date: Jun 2005
Member: 155820 Status: Offline Thanks Meter: 60 | Quote:
Nooooooooooooooooooooooo | |
The Following User Says Thank You to dhru_21 For This Useful Post: |
12-31-2005, 13:06 | #39 (permalink) | |
Freak Poster Join Date: Dec 2005 Age: 44
Member: 214350 Status: Offline Thanks Meter: 17 | Quote:
The Following User Says Thank You to naughtycell For This Useful Post: |
12-31-2005, 15:33 | #40 (permalink) | |
Member: 190492 Status: Offline Sonork: 100.01010100 Thanks Meter: 190 | Quote:
01-01-2006, 18:50 | #41 (permalink) |
Freak Poster Join Date: Mar 2004 Age: 45
Member: 59382 Status: Offline Thanks Meter: 2 | Moderators... Pls Close This Thread.. This Is Useless.. All Peoples Knw.. And Above Posts With Good Answers... Imei Patch Not Work. For ???????????????? Phone Will Off After 32 Sec Watch Dog Reset........ |
The Following User Says Thank You to fajar_kader For This Useful Post: |
01-02-2006, 21:09 | #43 (permalink) |
No Life Poster Join Date: Jan 2003 Location: Iassy Age: 59
Member: 19723 Status: Offline Thanks Meter: 359 | Don't post here stupid posts . Try to think why your phone IMEI is ???????????????????????? and then say that the solution doesn't work . Can you ? Why do you think your IMEI is "???????????????" ?!!?!??!!! |
The Following User Says Thank You to usernome For This Useful Post: |
01-03-2006, 13:33 | #44 (permalink) |
Member: 122246 Status: Offline Sonork: 100.50000 Thanks Meter: 4,993 | i have told many times that this solution is only works when imei corrupted in flash and it dosent get off in 30 sec is it clear now |
01-03-2006, 17:33 | #45 (permalink) |
No Life Poster Join Date: Oct 2003 Age: 43
Member: 40602 Status: Offline Thanks Meter: 118 | I'm very sad that you all just keep pushing Javajohn about his invention. At least respect for his works. I'm not saying that his solution is one hundred percent fake. I only can say that his solution is somehow work for him. This patching process is a copy cat from the original process of JAF. I have a 3510i with Imei ???? not ???4, i use JAF Imei Patch and it worked. Phone has new IMEI and IT CAN REGISTER AT NETWORK. It has signal, it can make a call. But it will shutdown after 30s. It really worked but since this patch cannot fool the phone that it has corrupted UEM IMEI DATA. Another example I have 7250i with Imei ???4, i used JAF Imei Patch, and it worked. 30s problems didn't occured in this 7250i. if i can assume: ???? = means that IMEI DATA in UEM is CORRUPTED ???4 = means that SIMLOCK DATA in FLASH is CORRUPTED If UEM DATA corrupt, UEM must be REPLACED If SIMLOCK DATA corrupt, please try Javajohn solution or JAF Imei Patch and try to post results here. Dont make a fool someone that already share his job results to you for nothing in return. Thats all i can say. ***Very good job Javajohn*** br, s1emens |
The Following User Says Thank You to s1emens For This Useful Post: |
..:: Cruiser Shell is here ::.. | indikait | Sony Ericsson | 7 | 06-14-2009 23:53 |
..:: Another Great N90/n70 Application Is Here ::.. | Javajohn | Nokia Multimedia | 92 | 05-30-2007 15:24 |
..:: The Best Ida.pro Is Here ::.. | Javajohn | GSM Programming & Reverse Engineering | 20 | 10-06-2006 17:26 |
..:: Solution Of Imei ?????????????? Is Here ::.. | Badhusha | Nokia Digital Core Technology 4 ( DCT-4 ) | 0 | 05-31-2006 07:25 |
..:: New Hot Nokia N 70 Applications Is Here ::.. | Javajohn | Nokia Multimedia | 43 | 01-27-2006 08:32 |
