09-01-2004, 10:13 | #1 (permalink) |
Freak Poster Join Date: Aug 2004 Location: www.Tools4Gsm.com Age: 46
Member: 79725 Status: Offline Thanks Meter: 5 | 3310 insted of op. name 000 00 and when do the set factory set it give 000 00 on lcd in stead of op. logo i change the (cobba and hagar and vco and ccont and antenna switch) and still same?? |
09-01-2004, 10:54 | #2 (permalink) |
No Life Poster Join Date: May 2004 Location: gsm-land Age: 45
Member: 67419 Status: Offline Thanks Meter: 237 | becouse your product code or imei number is ????????????? you must see better this . solution is to write a imei number or product code or to change flash ic best regards keany |
09-01-2004, 11:01 | #4 (permalink) |
Freak Poster Join Date: Sep 2003 Location: Czech Rep. Age: 43
Member: 40423 Status: Offline Thanks Meter: 5 | Keany> i respect u, but i had the same problem with reballed COBBA... it was used one. When i had used new one, then flash, recalculate, imei change.. phone worked... |
09-02-2004, 10:17 | #6 (permalink) |
Member: 67419 Status: Offline Thanks Meter: 237 | @yoda brno i respect you too and all here but with a 3310 with 5 zero in display is product code missing and i must do it very simple only write in 5 sec with wintesla . in your case you have resolve it when you have flash the phone and have recalculate imei .but in his case when he has change all the parts and its the same he must write a product code and imei if it is missing .and at the end if he fails all these ways and the phone is with the same problem , he must change the flash ic and his problem is superated with sucesfool . best regards to you keany |
@Genie Genie is best for flashing? Can i use Genie for flashig insted of other tools? | Jani-Jan | Genie Universal | 6 | 08-20-2009 10:24 |
Why delete my post insted of solve my problem. | Kiranmistry | Universalbox | 7 | 07-22-2009 22:03 |
how can i use Mozilla insted of internet explorer?? | invite | Smart-Clip | 8 | 04-06-2009 10:31 |
Active number display insted of operator logo? | analabri | Sim Cloning and Scaning | 8 | 06-06-2005 06:09 |
network: 000 00 | ReviveR | Nokia Hardware & Hardware Repair | 13 | 07-20-2004 21:25 |
