Motorola Old Legacy (EMMI) CD520, CD930, L7089, М3x88 (3688, 3788, etc.), P7389, P7689,T180, T192, T250, T260,T2288, V50, V51, V2288, V3690,V3688 and all Timport, Accompli & StarTack Families. |
06-19-2003, 13:44 | #1 (permalink) |
No Life Poster Join Date: Oct 2001 Location: No route to host. Age: 44
Member: 6772 Status: Offline Thanks Meter: 17 | IMEI changing problem When I change IMEI the leading digit is 0(zero) instead of 4. Phone doesn't make calls. I'm using RoEMMI2 with pemaster 2.10. This happens on v50(downgraded from 14.04), on m3888 after Phone Failed. It seems that pemaster writes IMEI incorrectly. I can't find any similar problem on the forum. Any ideas? Regards b0ba. |
06-19-2003, 22:47 | #3 (permalink) |
No Life Poster Join Date: Mar 2002 Location: Europe, Lemberstadt Age: 53
Member: 9889 Status: Offline Thanks Meter: 50 | @boba this problem was once discribed here generaly i dont use PEMaster for imei changing because this prog doesnt do it correctly instead i use something like UniversalImei.fdf, editing imei and after uploading by PEMaster for me its no quickly but better and working method br |
06-20-2003, 08:14 | #4 (permalink) |
No Life Poster Join Date: Mar 2001 Location: Ukraine,Kiev Age: 48
Member: 3529 Status: Offline Thanks Meter: 1 | PEmaster can change IMEI 100%..U must press UNLOCK after full flashing( after this sw show real phone IMEI) and then change it without problem. WBR. Peter |
06-20-2003, 13:52 | #6 (permalink) |
Member: 6772 Status: Offline Thanks Meter: 17 | Thanks all! I have solved problem yesterday just forgot to post. Phone was v50 F0.14.04 downgraded to 10.81. Here what I have done: Fullflash from TP. IMEI became 000000000000 Change imei in pemasetr. IMEI became 0xxxxxxxxxxxx Test card to phone then power on. Read flex. Manualy edit flex file to put correct imei in it. Flex phone. On phone press # (test) then 57# then power off/on Now IMEI is correct. Pemaster writes 00 40 to the beginig of SEEM 000C:01 however ir should write 08 4A or it just skips first two bytes. I tried manualy editing flex elier but without test card and 57# and after power off/on IMEI always returned to 0000000. I still doubt whether pemaster 2.10 cracked can change IMEI correctly. Anyway thanks everyone for help. ps: may be my way will be usefull for someone. WBR b0ba |
BF3 KJ255 imei change problem | _Gin&TONIC_ | BF, BG, TH, BHx Series | 0 | 07-18-2003 21:41 |
Samsung r210s IMEI changing problem | Felix Ament | VLSI, Conexant, Skyworks and Old Models | 0 | 10-02-2002 14:14 |
T20 imei change problem | kevin03 | Old Ericsson Phones & Sony Phones | 1 | 09-10-2002 10:57 |
maxon 6869 imei changed problem | digipulse | Various | 1 | 01-31-2002 18:14 |
GD90 IMEI change problem | jonwillow | Panasonic | 0 | 10-17-2001 16:10 |
